Absolutely agreedCitroening wrote:IMO, there's only one Xantia that looks nice with the 17" wheels on here...and that's Dean's!
Any1 got pictures of Xantia with 17" wheels
- x 8391
Deanxm
- x 87
yep, Howard Made a nice job of her, it just needs streamlining a little now
ive been out sprinkling a little barry away on her this evening actualy.
D
D
XM Prestige PRV6 92
Mitsubishi L200 Trojan 14
andmcit
- x 30
addo
- Sara Watson's Stalker
- x 95
Pompey_Dave
i dont have a handbook lolmyglaren wrote:I'll concur with that. I was a bit undecided at first but think it looks great now I've see some more pictures.Citroening wrote:IMO, there's only one Xantia that looks nice with the 17" wheels on here...and that's Dean's!
Really nice looking car there!
Whatever the handbook advises.What is the best grade oil
Asda have a very good offer on at the moment.
ETA:
No they haven't, finished today
addo
- x 95
Pompey_Dave
is magnatec a good oil to use?
Also, when it comes to adding wheels and that, im not into making it this big old modified barry boy car, been there, done that. All I want to do is add some nice wheels, maybe the spoiler, and colour code the door handles
Im not going for huge sound system (need that room for the nippers buggy and the dog), body kits, or huge graphics...Its just a case of making it cosmetically tidy really
Xantia2.0
@andmcit (picture of Xantia with genuine alloys) - I want those so much!! Although the non-original ones my Xant has are nice nothin compares to Citroén made originals! I saw in the paper there is a set for £55 (without tyres, came from a car with 34,000 miles on the clock!!). Though I've just had brand new tyres fitted to the alloys I've got already... Would taking them off and on again damage the bead ? (E.G make it more prone to leaking from the bead in later life ?).
1998 Citroen Xantia 2.0 16V I4 with 148,200 miles on the clock. Bought it with 123,000.
Onlinemyglaren
- x 5672
I'm sure it is but the downside of using expensive oils is that many are tempted to drag every mile and more from them.Pompey_Dave wrote:is magnatec a good oil to use?
I don't necessarily advocate that you adopt my policy but with the Xantia, I changed the oil and filters every month. It is so quick and simple and cost very little, the oil was always fresh.
I used Asda 10w40 IIRC. The advice was given by a seasoned mechanic and his advice on everything else was always spot on.
His stance was that as long as the oil complied with the ruling British Standard then it was fine and frequent changes meant it was unlikely to accumulate any significant contamination (water+exhaust gases = acids and other unpleasant compounds)
I still do this but with higher quality oil recommended for the HDi, changed at around half the recommended service interval, sometimes less (2,000 ish miles) if I'm in the mood.
It may not do any good but sure as hell can't do any harm
I would say that the Xantia never used any oil but that would be a bit disingenuous as it never had the chance to use any.
The C5 certainly doesn't use any, no top-ups between changes.
I can't remember which mode/year/engine you have but most oil manufacturers will have information specific to your car as far as which grade to choose - you don't have to use theirs of course, it is only the info you need to buy what suits you best.
I think the Citroen recommendation would be for Total/Elf 10w40 or 15w40 but that is little more than guesswork.
Try the Opie Oils website as it is a pretty easy one to navigate.
Click on 'products for my var then follow your nose through the questions to get to your specific vehicle.
Pompey_Dave
thanks for that, it said 10 40 aswell...Maybe I should of mentioned that it was a 1999 1.8 petrol version.
So, after all this im getting there now, cars getting better and better with all the info ive been gathering and doing all the little jobs needed on the car....But still, im confused as hell as to where the rear window heater switch is haha! I keep getting told its on the dash next to the hazard switch, but the only 4 switches I have on my dash is hazards, air con, traffic master, and the passenger door mirror!
addo
- x 95
Pompey_Dave
i have no picture or anything on either of the stalks, although it does look like there is some sort of button to press for maybe the top of the range models (you know where they use the same parts for the base model and the top of the range, but the base model doesnt have that gadget)
Just seems like it doesnt exist, yet its got the heating bars on the window!
jgra1
- (Donor 2021)
- x 36
Dave, my exclusive had a button that could/should have accessed the trip computer and I cant remember where the rear screen button therefore was..
by my other xantias, all have been that same button on the RH stalk, and once pressed you get a light in the top right corner of the dash.. try it? on my present car, the bulb was blown/missing.. all fine now I have sorted that..
andmcit
- x 30
Pompey_Dave
such a strange place to put it lol! Ive been searching for it for ages, as its been a bit misty in the mornings here....Although its not that bad and can cope with it, but I know its bound to get worse, so needed to find it before the weather gets colder in the morning, visability with these cars isnt great as it is lol!
