Hi
This is my first post.
Hope its not too silly a question, but my wife has a 2000 xantia 1.8i 16v
I checked the manual and it says coolant should be between min/max on radiator header box (which makes sense).
But having looked......its a black box with no visible min/max markings.
Can anyone shed some light on this for me.
ps I have searched the forum, but no luck, hence the silly question remark above.
How to check coolant level on Xantia
- x 8422
Welcome to the forum Biglittlebear
No question on here is silly.. What is silly is making expansion tanks out of black plastic
Check the level cold. Remove the cap and you'll see a plastic tube in the filler hole. The bottom of this tube has a slot in it and correct level is when the level is at the top of the slot.
Often, if you fill to this level, you may find it won't hold it and the level will drop to the bottom of the tube. This is fine as many Xantias seem to like to blow out what they don't want and establish a natural status-quo at the bottom of the tube.
If you can see coolant at the bottom of the tube and can't actually see the end of the tube, you're OK...
Biglittlebear
addo
- Sara Watson's Stalker
- x 95
- x 8422
Agreed. I'd be very tempted to do a coolant change so you know what's in there is good.addo wrote:Short term only, yes.
Refill with a 50:50 mix of water and antifreeze. The mixture strength will guard against any corrosion in the engine.
Keep an eye on the level. If it has fallen that much you may have a small leak.
Xaccers
- x 188
turn your heater on and sniff for curry/cat pee smell incase its leaking from the heater matrix
DIY sphere tool
DIY sphere tool
MikeT
- x 232
Until I had the matrix replaced, I would have agreed 100% with this.CitroJim wrote:Often, if you fill to this level, you may find it won't hold it and the level will drop to the bottom of the tube. This is fine as many Xantias seem to like to blow out what they don't want and establish a natural status-quo at the bottom of the tube.
I'm on my second TD Xantia and both would show this low level. No matter how many times I topped it up and bled it, I could never get it to hold the specified level, even when I added a bottle of K-seal which cured the curry smell. With a new matrix, it's spot on.
Perhaps we've discovered an early warning of impending matrix failure?
