What would you recommend as an alternative, Malcolm?citronut wrote:Mike if when lubbing dont us the W stuff it dries things out and dose not lubricate, oribl stuff,
I hear crickets
MikeT
- x 232
- x 94
Adam
your not spozed to put it into lock's because once it get water in there with, it cloggs the tumblers up then you get the urge to shuf more in because the lock is sticking, stuck in a cycle useing more and more of the orible stuff,
Mike
i use duck oil and buy it in a 5lt can, but even that i dont use in external door locks for the same reason as above,
regards malcolm
Mike
regards malcolm
- x 8391
Urrghaddo wrote: A main use I find for it, is cleaning my hands "in the field" with a half-decent scrap of rag to assist.
I agree with you Malcolm, 'orrible stuff, best off going to your local purveyor of DIY stuff and buy a big bottle of turps and mix a bit of LHM in with it.
Hey presto you have essentially what WD-40 is...
demag
- x 102
Ah sorry guys I wasn't suggesting WD as a permanent fix. Just spray into the balljoints and if your noise stops, then you've found the culprit. I always think noisy balljoints are doomed and would replace them asap.
Dave
- x 94
demag
- x 102
MikeT
- x 232
The crickets are breeding well. During a particularly warm spell, I had both front windows open and heard the chirping equally as loud from the N/S, whereas previously I was convinced it was the O/S. The noise is almost constant when driving straight, any slight left steering will stop it while slight right steering (or centre) will bring it on again.
I can rule that one out (though again, I'm not sure how to properly gauge the strut tops but they look ok)andmcit wrote:Wheel bolts loosening off!?... Or strut top failing?
Yes it does, as does application of the foot brake.Xac wrote:Have you tried gently applying your handbrake to see if that silences it?
As I was advised not to use WD40, I've yet to try this - would spray grease be ok or should I use something thinner like light machine oil (3in1)?demag wrote:Balljoints that are starting to dry out will creak. Try squirting some Wd40 under the rubbers.
Onlinemyglaren
- x 5674
Xaccers
- x 188
Handbrake silences it, it's your pads rubbing against the discs.
Cassy had this, her handbrake cables were sticking slightly, it's been fine since I replace the cable, although I do need to adjust it soon!
DIY sphere tool
DIY sphere tool
