Or that's what I first thought until I realised they must be nesting in the front O/S wing if they are crickets.
It's obviously something to do with the front wheels as I can shut them up by turning the steering as if taking up the slack, if that makes sense?
There were a lot of what I'd call exaggerated/superfluous advisories on my last MOT but none of them referred to steering parts (except the steering wheel top bush) so what could be worn to allow this chirping cricket noise?
I hear crickets
andmcit
- x 30
Xaccers
- x 188
Have you tried gently applying your handbrake to see if that silences it?
DIY sphere tool
DIY sphere tool
demag
- x 102
Balljoints that are starting to dry out will creak. Try squirting some Wd40 under the rubbers.
Dave
MikeT
- x 232
Erm, yes, that is a possibility actually, Andrew! Why didn't I think of it?andmcit wrote:Wheel bolts loosening off!?![]()
I daren't look, prefer to do an Emu and bury my head on that one! Perhaps I could take a wee peek but to be honest, I'm not sure how to gauge it specifically.andmcit wrote:Or strut top failing? God, I'm Job's comforter aren't I?
I will do so next chance I get, thanks xac.Xac wrote:Have you tried gently applying your handbrake to see if that silences it?
I did get the impression something had dried out so I'll try that trick also.demag wrote:Balljoints that are starting to dry out will creak. Try squirting some Wd40 under the rubbers.
Thanks all.
- x 5691
MikeT
- x 232
Xaccers
- x 188
Two managers where I worked in Staines used to always play practical jokes on each other, such as leaving skimpy knickers in the glove box for the other's partner to find!myglaren wrote:May be just crickets - do you keep lizards or tarantulas?
For revenge, he bought a load of reptile food crickets and released them in the panty planter's car.
They made home in the air vents and he never got rid of them.
DIY sphere tool
DIY sphere tool
- x 5691
Xaccers
- x 188
Blue 406 actuallyandmcit wrote:It wasn't a red Xantia by any chance Xac?
DIY sphere tool
DIY sphere tool
- x 94
Mike if when lubbing dont us the W stuff it dries things out and dose not lubricate, oribl stuff,
when i first started in the garage trade it was Henleys then Caffyns Folkestone, when delivery girls used to drop of deliverys, we would sneek out and put pebbles in there hub caps, BMC/F**D vans with the bash on hub caps, those were the days
regards malcolm
regards malcolm
demag
- x 102
Malcolm I always thought you were such a nice bloke as well!
Dave
- x 94
addo
- Sara Watson's Stalker
- x 95
Good for stiff house door locks, and power tool locking levers.
A main use I find for it, is cleaning my hands "in the field" with a half-decent scrap of rag to assist.
One product that doesn't get enough rap is Paslode/ITW nail gun cleaning spray. It's like carb cleaner but doesn't eat plastic connectors the same way.
