E.G.R Valve
guzgog
E.G.R Valve
Unread post by guzgog »
Am i right in thinking to disable the egr valve on a 2 lt diesel c5 i only have to remove the vacuum pipe and plug the pipe.
x 1053
Re: E.G.R Valve
Unread post by wheeler »
guzgog wrote:Am i right in thinking to disable the egr valve on a 2 lt diesel c5 i only have to remove the vacuum pipe and plug the pipe.
Thats correct but only if its working ok just now, if its stuck open then disconecting the vac pipe will do nothing.
guzgog
Thanks for that Wheeler, just one other thing do i need a special tool to remove the collar that holds the egr valve to the cooler. cheers Stan
ps sorry for the late reply comps been playing up
x 1053
There is a proper tool (clic pliers) for it but you can remove & refit them without damaging them with normal side cutters.
