What is the special trick to removing xantia tank filter.
falling-out-with-my-car
x 25
Hi,
I have tried to remove my Mk2 xantia 1.9TD tank sender unit and it just jamms half way up is there a special way it has to be raised or tilted to remove it please?
Thanks in advance Nigel.
jgra1
(Donor 2021)
x 36
Unread post by jgra1 »
should be quite straightforward nige..
a little angling as it comes up is needed though.. almost horizontal for a bit IIRC
John
Dommo
x 20
Unread post by Dommo »
If it's anything like in a 306 there will be a rod coming off it with a float on the end which moves on a variable resistor type thing that measures the tank fuel level. So this means you need to bring the sender unit out at a jaunty angle as said by jgra1
x 25
This is the problem I reckon thwere is a gremlin hanging on to the end of my sender unit and wont let go...lol
it doesnt want to come out.
Xaccers
x 185
Unread post by Xaccers »
Hold a can of sprite over it :)
DIY sphere tool
