Xantia with stubborn circulation slider
merlin617
Unread post by merlin617 »
my Xantia has developed a problem with the circulation slider
all the other slider are fine and I get airflow, I just cannot shut off the vent or completely open it, its stuck half open. Any help appreciated thanks.
Xantia 1.8 Sensation Hatch 1999
Saxo 1.0 1999
admiral51
(Donor 2026)
x 394
Unread post by admiral51 »
If you remove the trim around the radio/heater area (2 torx screws above ashtray remove ashtray first :wink: ) and then remove the radio (make sure you have code :twisted: ) you can then undo the 4 screws which hold the heater control box in place.Push the heater box back to free it from its locating lugs then lift up and pull towards you.The black cover on the top nearest the front will lever up and off.You can now access the innards :)
My guess is that the cable has become kinked and tangled in the mechanism.With lots of percy wotsits you can straighten the cable and full use will be restored.
In good BOL tradition refitting is the reverse of the above :lol:
Colin
merlin617
Thanks Colin
Saxo 1.0 1999
Stempy
Unread post by Stempy »
Had a similar problem with mine which turned out to be the vent flap catching on part of the foam liner behind the dash which had distorted with age. I fixed it when I did the matrix :shock:
Lexia ponce
red_dwarfers
x 58
Unread post by red_dwarfers »
If it is a kinked cable, you could also put a straw or something strawlike over a bit of it to keep it straight.
Kev
'19 C4 Cactus 130 Flair
merlin617
Stempy wrote:Had a similar problem with mine which turned out to be the vent flap catching on part of the foam liner behind the dash which had distorted with age. I fixed it when I did the matrix :shock:
good point but can you get to that foam without having to deal with the matrix. ?
Saxo 1.0 1999
Stempy
The reason I mentioned the 'm' word is that to get to the vent flap you have to take the dash out, so I did both at the same time.
Lexia ponce
Dannyboy
Cable kink
Unread post by Dannyboy »
Had this problem and straightened a kink in the cable and it works fine now.
Rgds..............Dannyboy.
merlin617
Thanks for everyone's suggestions it was a bent cable which I straightened. just adding some pictures to help anyone else in the future. These are the sort of pictures the BOL should have.
Saxo 1.0 1999
red_dwarfers
x 58
merlin617 wrote:These are the sort of pictures the BOL should have.
Sorry...it had to be done. Here is a 'Haynes conversion':
Kev
Xaccers
x 186
Unread post by Xaccers »
:rofl:
DIY sphere tool
merlin617
:lol:
Saxo 1.0 1999
