I have also "acquired" the Haynes Welding Manual.
405 Rust
evilally
- x 3
addo
- Sara Watson's Stalker
- x 95
- x 94
evilally
- x 3
Finally got around to playing with my new welder this evening. I managed to weld 2 vegetable oil tins together:
For some reason I find this hilarious. I've got enough of these tins to build a tower to the moon
Anyway, my welding is utter crap, lots more practise required.
'96 405 1.6 GLX with 306 GTI engine on Cat cams @ 195bhp
'05 RenaultSport Clio 182 Cup, 102k
'97 406 1.9TD, 314k.
addo
- x 95
- x 94
looking at those weld's you need a bit more penatration, as it dosen't look like you have blown any holes in those can's yet, and those welds look like there just on the surface,
cut one open to see how deap the welds have penatrated
if you can can weld those tinny's you will make a good dersh welder,
regards malcolm
regards malcolm
evilally
- x 3
addo
- x 95
Have you bought the new piece yet?
Cutting is best done "cold" - ie, using a reciprocating saw - as it doesn't embed carbon smut into the cut edge so badly. Failing that, try a thin cutoff wheel in a flex shaft tool or die grinder.
Spot welds are drilled out with a Wurth spot drilling bit or similar - it helps to lightly centre pop the weld first.
For that matter, get to know your Wurth rep as they do a couple of ripper primers - Acid #8 and also another weld-through zinc primer. Buy the 100g tube of copper lube while you're at it (immensely superior to any other copper grease).
evilally
- x 3
Update to this at last!
It failed on the rust on the sill, no other advisories. I set about chopping out the rust, lots of it:
I ended up chopping out a lot more than that
Took me ages, and it looks very frankensteinish, but it's strong which is all I need:
I'll leave it untreated until after it's restest. I plan to paint it over and seal it with some liquid rubber, much like what Peugeot used. I was thinking Ronseal roof rubber?
Can someone advise the best way of stopping it rotting from the inside out?
addo
- x 95
- x 1499
