Xsara cylinder head bolt washers
Badobsession
Unread post by Badobsession »
Hi all, im wondering if someone can help?
Im in the process of refitting a cylinder head after a cam belt failure but have run into a self inflicted problem as usual!!!
There are ten cylinder head bolts and eight washers that go under them, been a while since i took it apart and cant work out whether i have lost a couple or thats how it should be.
There is a spacer which i remember came from the drivers side rear bolt (looking down on the head from the front of the car) but a little concerned about the washers and if they do not use two which bolts should they be missing from.
The car is a 1998 1.8 petrol twin cam 16 valve and the engine is an XU7, LFY is the engine code.
Cheers, Rob.
x 1459
Unread post by xantia_v6 »
The bad news is that citroen service shows that there should be 10 washers, part number 0205 47 :(
Badobsession
Thanks for that, better get down the dealers tomorrow.
Cheers, Rob.
