ZX rear OS wheel rubbing wheel arch
Keith J
Unread post by Keith J »
Hi I have a problem as described in the title. I have an N reg 1.9 ZX elation estate and the inner sidewall of the tyre is rubbing a part of the wheel arch particularly when the car is loaded. It makes a squeak which sounds as if it's inside the car so it took some time to locate the source. Obviously this isn't right. I wanted to ask if this was a common fault if a shock absorber has failed or is it likely to be another fault? BTW there are no carbuncles etc on the tyre that are doing it.
I cannot see any obvious fault with either shock such as leaks etc but I need to do some longish drives soon. Any advice greatly appreciated on this and any pitfalls on shock replacement on a zx estate.
x 1489
The bearings are knackered in the trailing arm pivot. They can be replaced but it's a real 'mare job - better just to fit another rear subframe complete.
Keith J
Thanks for the reply. I will investigate that. Cheers.
Dommo
x 20
Unread post by Dommo »
You'll find that if the rear trailing arm bearings are knackered - which it sounds as though they are in this case - the rear wheels will have a lot of negative camber, so the top leans in towards the car.
If you look at the car from behind at a distance, you'll probably notice the rear wheels looking like this:
As apposed to:
Keith J
They look just like that. Thanks.
