xantia suspension pump
philxjr1300
Unread post by philxjr1300 »
hi i have a 2000 xantia which is casing me some problems with the pump is out of aliment with the rest of pulleys im wondering if some one has removed and refitted incorrectly does anyone know if there spacers to the pump :?:
MikeT
x 232
Unread post by MikeT »
There are several different pumps and when I enquired, was told the main differences are size and spacing/position of the pulley so it does sound like the wrong one's been fitted to yours, if I'm reading you right?
x 8400
What Xantia is it? Each engine variant has a differenet setup.
It is unlikely to be the pump. I had the same issue with an Activa fitted with the wrong Alternator pulling the belt a groove off the pump.
On a 1.9/2.1TD the automatic tensioner is also notorious for causing this problem.
As said, let us know the engine and we can be more specific...
