RPO number help please
steviewonder7
Unread post by steviewonder7 »
Hi folks,
Just a quickie........I havent quite fathomed out where the RP number for my car is stamped/painted/ stickered exactly.Ive looked in the drivers handbook and it doesnt appear to mention its location.Its not easy like the old Xantia was/is.
What i did find on the drivers side door arch nearby the footwell was a sticker that had the following:-
09510FV
EKQD
20104
Does anyone know what the sticker refers to?
Considering my car was registered in August 2003 would the sticker marry up?
Steve :?
1994 Xantia 1.9TD sx non anti sink.No aircon.Gone to the great scappy up above.
Now with Xsara Picasso 2.0 HDI (90 bhp)(03 plate) in 'Wicked Red'
Sl4yer
Unread post by Sl4yer »
9510.
James :D
Now Citroenless for the first time in 20 years
2008 Mazda RX-8 231
2007 Honda CR-V Auto
x 5673
It is supposedly a Four Digit number but I'm damned if I can find one on my car - I have photographed all the numbers on mine and as far as I can see the one you quoted appears to be the most likely one.
Mine is:
Only one that I can find that comes anywhere close :(
x 5673
Sl4yer wrote:9510.
James :D
I see - they hide it in among a bunch of other stuff :(
steviewonder7
Yes , mine appears to look similar to the bottom sticker of the two you've shown in your pic.
steviewonder7
Forgot to mention...thanks for that sl4yer. :roll:
VertVega
x 13
Unread post by VertVega »
You've already got the answer and here's some more :)
9510 --> Production date is 22 November 2002 (from Citroen Orga Calculator)
EKQ --> is the paint code. You car's called "Wicked Red" (you might need this also some day)
Dieselman
Unread post by Dieselman »
myglaren wrote:It is supposedly a Four Digit number but I'm damned if I can find one on my car - I have photographed all the numbers on mine and as far as I can see the one you quoted appears to be the most likely one.
Later ones are five digit as the number of days is now over 10,000 since 9th November 1976, which was day 1.
VertVega
x 13
myglaren wrote:It is supposedly a Four Digit number but I'm damned if I can find one on my car - ...
myglaren, your car has RPO number 9387 --> production date is 22 July 2002
paint code: EZR --> Arctic Steel
x 5673
That ties in reasonably well with the date on the headlights - 15th July 2002 13:28 - a bit more precision than really needed there!
steviewonder7
Thanks for the info Vertvega...it will come in handy one day :)
KevMayer
Unread post by KevMayer »
My C5 is 9362 which is also July 2002 as far as I can tell.
Cheers, Kev
frenchcarnut
Unread post by frenchcarnut »
Trying to find this on my mobile skip (2000 reg C15 panel van), but can I find it? Can I heck. Should be around 8500
Awaiting Citroen's support via VIN number but not having much luck getting a response from them either.
04 C5 2.0 Auto HDi VTR
frenchcarnut
frenchcarnut wrote:Trying to find this on my mobile skip (2000 reg C15 panel van), but can I find it? Can I heck. Should be around 8500
Awaiting Citroën's support via VIN number but not having much luck getting a response from them either.
Finally got it. as 8579. But didn't help much as the clutch cable I wanted cheaper than £36 + VAT is Citroen only part according to at least 3 independents. Ho hum!!
