Injectors
KennyW
x 165
Injectors
Unread post by KennyW »
Hi All,
What size is the injector removal socket for my diesel Xantia?
Kenny
C3 1.4 petrol (SWMBO)
x 1052
Unread post by wheeler »
27mm
Xaccers
x 188
Unread post by Xaccers »
Be careful with the leakoff spiggots.
DIY sphere tool
KennyW
x 165
Thanks Guys.
citroenxm
Fallen Hero
x 70
Unread post by citroenxm »
And S2 - well, actually, Late S1 from 1997 with knock sensor!!
You'll need a cut out hardened socket for that one!!!
Paul
A very sad...
1994 XM 2.1 d auto
KennyW
x 165
Hi all,
On Tuesday evening I noticed a new problem develope which I think is the injectors.
I ran the car on Tuesday morning taking my laddie to college about 2 hour drive around auld reekie with no problems including the bypass.
On Tuesday evening as I accelerated there was a sudden jerking at approx 2800rpm. I stopped the car in emergency layby and checked the pump okay but same problem violent shaking at 2800 RPM.
It is my intention to check the injectors soon as I believe this will cure my running issues at idle.
Could this also be part of the problem :?:
Kenny
