Toby's Activa and 406 Coupe
x 8401
Toby_HDi wrote: Anyway, the Coupe is going for an early MOT tomorrow. If it fails, I will transfer cover to the Activa. I have a horrible feeling it is going to fail spectacularly.
Why? What do you suspect?
Toby_HDi wrote: I can then start sorting it while driving the Activa.
So, see you next weekend then....
Toby_HDi
x 3
Unread post by Toby_HDi »
Not had the car back yet but it has failed. I discovered this on the MOTinfo site....
Offside Front Lower Suspension arm has excessive play in a pin/bush (2.4.G.3)
Nearside Rear Registration plate lamp not working (1.1.5c)
Front Horn does not function (1.7.1b)
Interesting the horn doesn't work! The lower arm bush I assume is the wishbone? I was suspecting the rear as it feels twitchy, not the front. Could this be the cause of the twitchy roadholding? Even so, how easy are these to do? I know there are two on each wishbone and I might as well do both sets. Ideally, I'd like to get it done soon so I can go to Beaulieu, if not then nevermind.
Also advisories....
Nearside Rear Tyre worn close to the legal limit (4.1.D.1)
Rear Brake pad(s) wearing thin (3.5.1f)
I knew about the tyre, thankfully it is just an advisory and rear brake pads is not an issue. Simple job methinks.
Toby
Previous:
2004 Peugeot 407 HDi 138 SE Luxury Pack
2001 S2 Xantia HDi 110 SX
2001 Peugeot 406 V6 Coupé
1998 S2 Xantia Activa
2000 S2 Xantia HDi 110 SX
1999 Peugeot 406 2.0 16v Estate
jgra1
(Donor 2021)
x 36
Unread post by jgra1 »
toby thats all ok :)
lower arm is similar to all psa cars.. two bushes and a ball joint are it's three points of contact.. a new arm may not be that much, otherwise you can pull the failed one off, grab someone with a press :) and get the failed bush replaced..
option one is easy but £50 or so.. option two more like £8 but the press is the key...
J
x 8401
That's not too bad them Toby.. Could have been a lot worse...
Press in my garage...
DickieG
Monaco's youngest playboy
x 33
Unread post by DickieG »
CitroJim wrote:That's not too bad them Toby.. Could have been a lot worse...
And on the way pick up your new jack :lol:
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
x 8401
DickieG wrote: And on the way pick up your new jack :lol:
You'll love your new jack Toby...
They're brilliant and just the job on a low-slung car like the Coupe..
Toby_HDi
x 3
Right well I've collected the car.
The horn does work, so not sure why that failed.
I think I may just change the wishbones. They are £50ish each from GSF and it whilst I appreciate Jim's offer of a press, it is probably just as economical to replace the arms.
I'm toying with the idea of rear bushes too, though nothing was mentioned on MOT so I may leave them be for now. Hopefully, two front wishbones and a 4-wheel alignment and it'll be good again.
I take it the wishbones just unbolt? Do I need a splitter?
One other thing I'm confused about is whether I can drive the car. The current MOT expires on June 3rd, but now that it has failed this one, does that invalidate it? I'm being told I can drive it til June but I have a suspicion that I can't.
Toby
Previous:
Sl4yer
Unread post by Sl4yer »
Toby_HDi wrote:One other thing I'm confused about is whether I can drive the car. The current MOT expires on June 3rd, but now that it has failed this one, does that invalidate it? I'm being told I can drive it til June but I have a suspicion that I can't.
I'm certain you can Toby. The law only requires that you have a valid MOT, which you have. Unless they said it's dangerous you'll be fine.
Now Citroenless for the first time in 20 years
2008 Mazda RX-8 231
2007 Honda CR-V Auto
jgra1
(Donor 2021)
x 36
+1
you can drive it Toby
MikeT
x 232
Unread post by MikeT »
x2, you current MOT has not been overturned.
My Ashtray failed and it was classed as dangerous. However, I drove it home like I stole it. :lol:
Gingerposer
x 6
Unread post by Gingerposer »
http://www.mottest.net/mot/mot-failure-question/
I had a look into this a while back and it appears that failing the test does not invalidate the current mot IF and only if the defects on the fail report are rectified before driving the car on the road.
Ainslie
Sl4yer
That's a bit misleading in a way. The MOT is
only proof of roadworthiness for the moment it's issued. Having a current MOT is not proof of roadworthiness, but is a legal requirement. Toby currently meets this requirement. I don't think there is any intention in the law that a car that fails it's test cannot be driven. Many things, such as retests, provision for getting to a test with no certificate and the Danger notice support this.
The example given in the article (worn tyres) is an extreme case, and something that most concientious car owners would never risk failing on, or even driving with, regardless of MOT.
2008 Mazda RX-8 231
MikeT
x 232
jgra1 wrote:option one is easy but £50 or so..
I've agreed to assist but I've only experience of doing one on a Ford Escrot and that was in a garage, using power tools and car lift.
I hope Toby's got the BoL but in the meantime, does anyone have a brief of the job so we can be as efficient as possible? I recall power tools, brute force, serious leverage and plenty of space under the car was required but that might just have been me and my time-conscious boss's methodology.
Sl4yer wrote:That's a bit misleading in a way.
Agreed. It's cleverly worded to imply the MOT is invalid until the tyres have been replaced but that's not the case. The MOT remains valid. What is true is that the driver could be charged with other traffic offenses, but it won't be for not having a valid MOT.
jgra1
(Donor 2021)
x 36
hi Mike.. similar to a Xantia really..
jack-up, wheel off, maybe wheelarch liner,
split outer lower ball joint,
split track rod end.. (should allow strut to move out of way (may be worth removing strut brace and rebolting strut top loosely))
and undo the inner bush bolts..
I think that's it although there may be a drop link to remove too..
then the arm should just come out :)
I think on reffiting you may want to get some car weight back on the wheel before you tighten the inner bush bolts, so they are not prestressed..
anyway, and 406 BOL will guide you through, but arm changing should be pretty straightforward really..
MikeT
x 232
Thanks John!
