help please WTD 1.9TD Xantia PAS return valve
bigblock
Unread post by bigblock »
hi all,im just new here,so please be gentle.after try unsuccesfully for three days to find a return valve for power steering the one on the passenger side bulkhead with the two metal connectors and with the rubber hose that goes to the steering rack i wonder if some kind soul can tell me where to get one,ive tried dealers and online breakers all to no avail,regards bb
x 1938
Probably need to know what car it's for... :oops:
bigblock
sorry matey,xantia 1997 1.9 turbo dlx.bb
Xaccers
x 188
Unread post by Xaccers »
I've updated the title to be a bit more descriptive :)
DIY sphere tool
x 8389
I cannot think of what part this is bigblock :?
The only Xantia I know with something that vaguely fits this description is the V6 and that item is utterly unique to that vehicle and mounted on the nearside chassis rail below the battery.
Can you post a picture of the item in question please?
What is the problem it is causing?
bigblock
hi,ive been told that its a cigarette sized aluminium box mounted on the inner front wing,it has two metal couplings and a rubber over flow type pipe.it also has two couplings blanked off with two screws,it is sited above the nearside drive shaft,oil is peeing out of these bodged blanks.bb
x 94
Unread post by citronut »
that will be the anti sink valve, and can be fixed by just unscrewing the end/cap and fitting a new O ring,
below is the part and trade price you would require if fitting new and not just a new seal,
0000529302 VALVE 81.88 GBP 96.21 GBP 96.21 GBP
0000529301 VALVE 81.88 GBP 96.21 GBP 96.21 GBP
the first one is for cars with HYDRACTIVE, and the second one for NON H/A,
regards malcolm
addo
Sara Watson's Stalker
x 95
Unread post by addo »
Malcolm, is there anything special about that O-ring?
I'm asking because (if mammary serves me correctly) it fails on most cars around 100K miles. So - mine's about due anytime! People here have intimated that some aspect of it was different to a regular O-ring.
Thanks, Adam.
x 94
citroen dont list the seal for the anti sink valve, but i sure it is the same as one of the two diferent sized pump seal,
Martin from Pleaides i think says the prob is caused be the seal seat in the A/S valve body
regards malcolm
bigblock
sorry for the late reply but the small aluminium box is on the passenger side under the bulkhead above the nearside drive shaft,im still being told that it is a return valve and if taken off for a length of time the whole front end wouldhave to be fork trucked up,sorry for this but im a numpty im at a loss now as one dealer sent me a abs box and im told that it is the small fag box part that i need,HHHEEEELLLP PPLLEEASSE.BB
