veg oil
Dommo
x 20
Unread post by Dommo »
I've got one of those heaters, but we've not yet fitted it. As daft as it sounds, it's quite difficult to find somewhere for it to mount, it's pretty beefy!
Napoleon
x 4
Unread post by Napoleon »
So is there a strong justification for having it, then, Dommo?
Tim
2009 HV09 C5 2.2
1996 N679 Xantia TD VSX estate - sold August 2012
1995 M289 Xantia TD SX hatch - sold March 2012
Tarte au Citroen
2009 24" iMac 3.06GHZ
KP
x 27
Unread post by KP »
Waste of time and money to be honest those things as the heat you can put into the fuel using one will soon be lost in the metalwork it then has to travel through to get out of the injector nozzles...
MikeT
x 232
Unread post by MikeT »
They might prove useful when the temperature drops below -10 but otherwise they are not really IMHO. Yes, they will improve cold-starting and might have other slight benefits but once the engine warms up - they're redundant.
Xaccers
x 188
Unread post by Xaccers »
Napoleon wrote:@ Xac, from your posts here about SVO then, you'd say there was no need for one of these? ->>>
Never needed any extra heating with SVO.
Just a bit of diesel when it's icy.
DIY sphere tool
Napoleon
x 4
Thanks Xac.
Tim
2009 HV09 C5 2.2
Tarte au Citroen
gadgetgricey
Unread post by gadgetgricey »
Sorry to hijack the thread a little, but reading the above with interest.
Have an R Reg Xantia TD, wondered if I can use SVO in it, and if so what percentage split would people recommend.
Also rather a numpty question, but how can I tell what/where the fuel pump is as noted a previous comment re Bosch and Lucas.
Costco is calling me :D :D
Thanks again..
- Dave -
C8 - Petrol Auto (Love the electronic doors)
Xantia Hdi Exclusive Estate (gone but not forgotten)
Xaccers
x 188
1.9TD Xantias were fitted with Bosch pumps.
Start at 50/50 and work your way up.
After 500 miles or so, swap out your fuel filter, making a note of it's colour (golden/brown suggests a lot of gunk has been cleared out of the tank), change the filter again at the next 6000 service, and every 6000 service from then on.
Also pop the fuel sender out the tank under the rear seat (driver's side) and give the filter in there a good clean as it's going to be gunked up with 12 years of dirt/diesel loving algae.
DIY sphere tool
HDI Dave
x 3
Unread post by HDI Dave »
steelcityuk wrote: Just in case anyone should wonder - never run a common rail diesel on veg oil.
Steve
Mine's a common rail isn't it? 1999 T reg 2 litre Hdi. Sorry to sound thick..i'm old school and was hoping i could just bung a few litres in here and there,but i'm sure i can't.What would happen if i did?
Wouldn't want to wreck the pump either,so i'm just asking out of curiosity.
1999 Xantia LX 2.0 HDI 110 Rusteration project...
den169
Unread post by den169 »
I wouldn't risk it iv'e seen posts from people running an hdi on it,but others saying it will damage the engine big time.I have a c5 but won't use it in it,But i also have a Mazda pickup which touch wood will, iv'e just started using it in the Mazda its an old 98 one and i'm trying 50-50 diesel veg.
x 8389
Absolutely. The ONLY engine that can run veg safely is the 1.9TD XUD with a Bosch pump.
ANYTHING else must not see any veg. Not even a 1.9TD if it has a Lucas pump.
Lucas pumps of all flavours (especially the 2.1TD EPIC) quickly die if run on anything other than DERV. I'm not even convinced there pumps are happy on biodiesel.
Anything common-rail is definitely out for veg.
KP
x 27
Unread post by KP »
I ran my old 2.0HDi 90 on Bio for many miles, circa 20k without fault.
My dad ran it on his c5 for a bit and had a poor starting issue for a month or so but i think this was due to a bad batch...
Chris570
x 36
Unread post by Chris570 »
i ran my last xantia on veg and the biggest improvement was to fit a lift pump because the veg can be a bit thick and fuel starvation is very possible, especially in the cold weather.
make sure the pump doesnt pump at too higher pressure though 3-6psi ideally.
also watch out for the fuel filter housing as they can leak air in causing all sorts of fun and games
falling-out-with-my-car
x 25
if you buy the three litre bottles at tesco's it works out at around 85p per litre buy 1 litre bottles and it works out over a pound a litre.
I run filtetred WVO all the time but I do change my fuel filters every three months religeously.
my Dads Mk1 xantia came to a sudden stop the other day and need a breakdown truck to bring her home, the filter hadnt been changed for at least a year it was all gelled up. with no throttle response.
bought her a new filter drained out the filter housing, filled it with diesel magic injector cleaner replaced filter stuck the lid on started the engine went for a test drive all cleared out and back to normal.
added some rug to the tank to as he was running on straight filtered WVO.
5% thats 1.5 litres petrol to 20 litres of oil.
cheers Nigel.
den169
3 lt bottles at tesco's are £2-53p but buy one get one free see my other post so around 42p a lt not 85p till the 18th.I bet they run out before then.
