C5 SatNav not working
andyf117
Unread post by andyf117 »
As per my previous post 'C5 Newbie, Help Please!', after recharging and reconnecting the battery in my 2.0HPi Exclusive, the SatNav has been disabled - as in 'greyed out' on the display, and unable to be selected from the menu.....
I assumed this was simply because it had spat the map disc out - however, after re-inserting it, it still doesn't work. It sounds like it is trying to read, but after a minute or so the disc ejects itself - it then sucks itself back in and has another go, with the same result each time.....
Have tried the software disc, which does exactly the same thing - sounds like it's reading then ejects, re-inserts, then ejects again, ad nausem. The SatNav and Map icons on the display continually remain inaccessible....
Any advice or suggestions, please?
x 1044
Unread post by wheeler »
If you disconnected the battery while the BSI was still awake & the little red light on the CD drive was still flickering you may have damaged the navigation ECU.
KevMayer
Unread post by KevMayer »
It sounds like the cd laser may be dirty. Try running a laser cleaning cd in the drive.
Cheers, Kev
andyf117
Damaged ECU sounds expensive - presumably the only way to check is to have the car hooked up to a diagnostic system?
Will try a CD cleaner and hope it turns out to be that - much cheaper fix, if so!
andyf117
Have just tried a CD cleaner, which has made no difference, so it's not a simple £1.00 fix.....
Wondering if disconnecting the battery again, leaving it for a while, and then reconnecting may do a 'reset' - or would that risk further problems?
