Engine Undershield
- x 5666
Xaccers
- x 188
If you've removed/lost the sheild, then it's a good idea to trim back the wheel arch liners so that they don't flap about.
DIY sphere tool
DIY sphere tool
HDI
- x 7
Before I refitted my undertray I used cable ties to attche the liners to near by body work.
Now using '00 Xantia LX HDI, pov spec
My past Citroens :-
'00 Xantia SX HDI, now dead due to accident
'99 Xantia HDI 110 Exclusive, RIP
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
'79 CX2400 Pallas (scrapped
& a couple of Peugeots !
My past Citroens :-
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
steelcityuk
dieseldoggy
lexi
- x 134
Surely they must also give some protection to road spray. Better with protection than without. We know why there is none on our V6s..............heat . They would melt
French Mistresses gone.
Citroen C5 HDI Mk 1 hatchback
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
Clogzz
- x 40
- x 1240
rmunns
- x 9
falling-out-with-my-car
- x 25
Took my SX diesel estate undertray off 40,000 miles ago and threw it away doesnt affect milage or warm up only thing is does effect is how numb your fingers get trying to remove it to get to the underside of the engine in freezing cold winter temperatures.
it doesnt protect your sump from folded parking pillars
in fact the only thing it served a use for is to stopp animals crawling up inside the engine bay in the winter time to keep warm and consequently being cooked in the engine bay because they were far to scarred to jump from a vechicle travelling at 70+ mph.
in fact I wouldnt mind betting that is exactly what it was designed for i bet there is some kind of French creepy crawly that likes sleeping in nice warm engine bays.
regards Nigel.
regards Nigel.
johnway
Thanks everybody !!
Great answers all, many thanks. I have driven the C5 for a few hundred clicks now and have not noticed anything different with the under tray off so will continue without (unless I stumble on a good used one for replacement).
Regards,
John.
Regards,
John.
My chariots : 2002 Pug 406 110 HDI Executive Estate 138K
1995 Citroen AX 1.0 Debut 26K
I Blame it all on my Dad!! (Sadly had to give up driving & his 2nd BX) but Mum still has a C1.
- x 5666
I removed my airbox today, partly to investigate the air hose it breathes through, partly with an aim to test the reversing light switch.myglaren wrote:Mine is in my garden too since I changed the oil/filters last week, was attached with tie-wraps.
I noticed while under the car that the 'hose' from the wheel arch to the airbox seemed to be stuffed with something. Has anyone else noticed this? Is it some form of pre-filter or have I just collected a ton of leaves and muck
The airbox was full of leaves and water:
I drilled a small (1mm) hole in the side and allowed the well to drain a bit - as seen here, It was completely full before drilling the hole.
Removed it and washed it out with the garden hose.
Investigated the feeder hose and it isn't full of socks or leaves, it is just the construction of the hose makes it feel that way, has some kind of lining to it.
Was unable to get the plug off the reversing light switch, bit leary of damaging the connection but did note that the clutch slave is fitted with a bleed nipple:
I presume that the gubbins in the centre of this picture is the ABS pump - looks a likely candidate anyway.
Clogzz
- x 40
Hi Steve,
I did look when you wondered back then, but didn’t see any benefit from getting back to say that I got nowhere at trying to find the hidden air intake.
The tube did feel hard with something inside, like a rigid hose inside an outer concertina shroud.
I had the same amount of leaves in the box, but no water, hopefully because the arch liners and floppy air deflectors were always in place.
The gubbins are indeed the ABS pump, with the four pipes screwed into the top visible from in front of the battery.
- x 5666
I have heard several reports of that well being full of water and there were lots of leaves and water in there when I changed the air filter a couple of months ago.
I have also heard of others doing the same mod. I did wonder why they put that well on there with no drain for the water - perhaps it is supposed to be there? But in dry climates it wouldn't last long anyway - I suspect mine was full due to me barging through puddles and floods, been lots of them recently
What happens when it overflows
boristhespie
- x 4
How much is an undertray for c5. Mine disintegrated at 70mph. I stopped thinking I had a pucnture then continued to see black shards flying behind me. Then had to change it in a suit in a huge pishing rain storm on a farm track the side of the dual carriageway.
it is sitting in mygarage. Well what's left is.
The other c5 is stuck on with a bit of string.
How mcuh are these?
How mcuh are these?
C'est pas possible!
