LHM reservoir level
Dommo
x 20
LHM reservoir level
Unread post by Dommo »
I've got a quick question about the LHM reservoir..
I read somewhere that someone had enough LHM in their reservoir to be able to cover their index fingertip when they put it in the reservoir on service high, but I can't reach the LHM with my finger, and my guage says my LHM is full. So is it wrong??
Thanks, Dom.
Toby_HDi
x 3
Unread post by Toby_HDi »
Give the glass that houses the float a firm tap.
They can get stuck
Toby
Previous:
2004 Peugeot 407 HDi 138 SE Luxury Pack
2001 S2 Xantia HDi 110 SX
2001 Peugeot 406 V6 Coupé
1998 S2 Xantia Activa
2000 S2 Xantia HDi 110 SX
1999 Peugeot 406 2.0 16v Estate
Xaccers
x 188
Unread post by Xaccers »
Are you sure they didn't mean on low?
Perhaps you're like me and don't have piano players fingers :)
DIY sphere tool
Dommo
x 20
I do remember it saying on service high, but if you're not supposed to be able to reach it then that's fine! Although I may possibly have put some in to see if the float would move, and to see if I could reach it with my finger... Maybe possibly :lol:
Is too much LHM bad?? :oops:
Cheers, Dom.
Xaccers
x 188
It's only bad if you like a clean resevoir.
Any excess just gets sloshed around and can spill out a bit.
DIY sphere tool
Dommo
x 20
Ahh, well in that case I probably did have too much in as the top of my reservoir is always wet, I just assumed it was a dodgy seal to be honest.
Thanks Xac. Dom.
Sl4yer
Unread post by Sl4yer »
I always thought my float was stuck until my rear ram started to leak. Now I know it works! (And the STOP light warning). :(
Now Citroenless for the first time in 20 years
2008 Mazda RX-8 231
2007 Honda CR-V Auto
x 8422
Sl4yer wrote:I always thought my float was stuck until my rear ram started to leak. Now I know it works! (And the STOP light warning). :(
James, what news of your ram?
I've now done a repair of a leaky rear one and it's back on the car awaiting test... Just got to do the front one now...
Have you seen the reams of words about repairing them in the Activa area and my blog?
If it works, the cost is less than a tenner and about an hours' work (after removal from the car).
Sl4yer
I've been following your progress with interest Jim. Mine has stopped leaking for now (so I think it's definitely something to do with the exceptionally cold weather). I'm going to get my Activa spheres regassed, probably by Westroen, and hope that will prevent further leakage when it gets chilly again. MOT time is November, but I'm tempted to go for a summer one instead.
Your repairs sound encouraging though - a much better solution that the original! I may be needing your help at some point... :)
2008 Mazda RX-8 231
