Hi, the gearbox on 1997 xantia 2.0 petrol has given up the ghost. So i am looking for info on what other auto boxes would fit as i have been offered a box from 1994 XM Turbo. Would this be compatable or is there any from the peugeot/renault range that would fit?
Many thanks
John
Xantia Auto Box
- x 8391
Hi John,
Welcome to the forum
Your '97 Xantia could eiter have the ZF 4HP14 if it is a MK1 or the Siemens AL4 if it is a MK2. The HP14 is a hydro-mechanical 'box whereas the AL4 is an auto-adaptive electronic device. The latter will have a "Sport" and Snow" button.
Generally, it is not possible to swap to a different 'box, they must be replaced like-for-like. You even have to be careful about using the same gearbox but designed for use in a different car. The 4HP14 was used in the Pug 205 and 405 but the 205 version (and likely the 405 one) will be all wrong for use in a Xantia. The same applies to an AL4, only moreso..
I believe the 'box from an XM will be a 4HP18.
You say the 'box has given up the ghost; how and in what way?
johnlad_27
- x 8391
What? Seized in gear in that the gear selector won't move and hence the broken cable or seized in that the gearbox is locked up solid?johnlad_27 wrote:The problem is it has seized in gear, and as a result of me trying to force it, the cable has snapped.
I would hazard that you may have a problem with the Park Pawl so the RAC man might be right, a bearing might have collapsed and in doing so, upset the Park mechanism. The Park mechanism is directly operated by the selector cable and if damaged in any way will cause a seizure.
Normally though, bearings dont just collapse and fail. Normally they do give a bit of warning... Usually by a scream...
You've not identified the 'box...
Whatever 'box is fitted, they are repairable, the ease of which depends on what's failed.
johnlad_27
