Fluid Leak
Ross
Fluid Leak
Just noticed a fluid leak which is coming from the large nut and pipework on top of what I think is the fluid pump driven off the engine belt - is it safe to simply tighten the nuts up or is it best to take the thing apart - is there a copper washer or similar that is likely to require replacement - been here before - seems simple but then gets complicated - lol - must be an Xantia thing
- x 8400
If you mean a leak from UNDER the 199mm nut the 12mm flare nut for the hydraulic supply pipe to the regulator screws into then the job is a simple one.
All you need do is replace the O ring under the big nut and these cost pennies from a dealer.
Confirm this is where the leak is coming from and one of us will supply the part number.
NEVER, EVER try to stop leaks by tightening things up. It makes it worse at bast and invariably causes damage. A nip is enough.
- x 8400
Early? Been up hours!!!!Ross wrote:Thanks Jim - knew you would be up early - lol
Here's the O ring you need Ross... Item 5
The stealer may make you buy 10. No worries, just sell them on here - there's always a ready market...
Take care removing the 19mm nut as there is a big spring under it. Go easy as if the spring jumps it may disturb a ball and seat.
be prepared for a big LHM spill too...
citroenxm
- Fallen Hero
- x 70
You may also know theres a Blank'd 19mm nuts on the opposite outlet!
Ive got one of these leaking, is there also a Spring, disk and ball behind the other one? Does it use the same seal?
Leak behind the nut thats facing directly downwards in that diagram
Paul
Paul
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
- x 8400
- x 94
Old-Guy
- x 26
Where do you buy a socket that big!CitroJim wrote:If you mean a leak from UNDER the 199mm nut......
Xaccers
- x 188
5 goes on the 19mm pipe union and the 19mm blank on the other side of the pump (not visible in Jim's picture)
4 goes under the torx ones which I have to say, I've never seen leak.
DIY sphere tool
DIY sphere tool
- x 5672
Xaccers
- x 188
myglaren wrote:It's only 7.83464567 inchesOld-Guy wrote:Where do you buy a socket that big!CitroJim wrote:If you mean a leak from UNDER the 199mm nut......I bet Candy will have a spanner to fit that
DIY sphere tool
DIY sphere tool
