C5 Temp Warning
amjake
C5 Temp Warning
Unread post by amjake »
Hi All
Each morning for past week on switching ignition on the
STOP comes on, Temp gauge goes up to red, and console binnacle reads "Engine Coolant Temperature Too High" and beeps 3 times
all before firing ignition up.
All clears on start up but beeps three times and then temp gauge drops down into the blue.
Suggestions to rectify please? Have changed thermostat on recent full service 2000 miles ago
Cheers
Kevin
fred1
Unread post by fred1 »
Hi,
Sounds like the temperature sensor is faulty.
Had a similar problem and changing the sensor fixed it.
John
JohnD
(Donor 2022)
x 72
Unread post by JohnD »
We had these symptoms on the Xsara. Changing the sender in the end of the cylinder head cured it.
2010 C5 X7 VTR+Nav 160
1998 1.5 Saxo
1998 Pug 306 1.9D
2018 C4 B7 VTR+
2011 Citroen C1
Julz
Unread post by Julz »
you probably disturbed it when you changed the thermostat. It may need replacing or could simply be a dodgy connection. I'd check the connections before replacing it.
1999 306 1.9TDi meridian estate (written off)
2001 C5 2.0HDI LX estate
Citroenmad
x 110
Unread post by Citroenmad »
I had this with my 2.0HDi 206, it was the temperature sensor in the side of the engine block.
24 Toyota Yaris Hybrid
03 Seat Arosa 1.0S
amjake
Thanks all for the replies.
Checked connections all looked fine and as I'd purchased the sensor and 'O' ring I replaced it.
Lo and Behold no alarm, car warms quicker and hotter!
Cheers
Kevin
x 1938
Temperature senders seem to cause problems, other than those which you might expect, when they go wrong.
A few years ago I was ready to change the single point injection unit in my daughter's VW Polo 1.3 because it was overfuelling. I was told that the temp sender quite often goes wrong and so replaced it. Result - engine ran perfectly.
