Hydraulic line leaking
davetherave
x 4
Unread post by davetherave »
I did have the same pipe fail most unfortunatly at a rally last year!
I got martin to make me a pipe with a large coil in it, whilst this pipe works fine, the steering does pulse a bit and the noise is transmitted into the car.
However it was a cheap fix that worked great, and is still working fine!
The old pipe leaking is here Image
Good luck in fixing it!
(95) XM Silver 2.1td Exclusive.
(87) Cx 2.5 DTR T1 undergoing major cosmetic surgery.
GPZ500s
seany87
Unread post by seany87 »
It was the pipe at the very front, in front of the one with the coil in it.... not sure what it does though.
Dommo
x 20
Unread post by Dommo »
Call me stupid, but what exactly is the point of the coils of pipe, is it to dampen pulses of high pressure fluid so it doesnt wrench the pipes??
Cheers.
x 8391
Coils only make an otherwise rigid pipe flexible Dom, in being flexible, they can withstand but but not damp or isolate vibration. You find coils wherever a rigid pipe makes a transition from a fixed to a movable object, typically from engine to body and body to rear trailing arms. You will see there are no flexi lines to the calipers at the rear. Coils in the pipes take their place.
A rubber pipe (as in the PAS ram supply) will provide flexibility, vibration isolation and a degree of pulse damping.
scoles
Unread post by scoles »
off to the hydraulics company that we use at work tomorrow and if they cant do anythying with it then its back to the dealers :(
