Xantia Blower - FINALLY FIXED!!!
- x 1240
- x 8378
If this is the wire going to pin 3 of the brown plug then +12v here will stop the fan whereas an earth will make the fan run at full speed.Peter.N. wrote:That will be your problem then, if I remember correctly there should be around 3 volts on this wire, its the control signal from heater panel, if you connect it to 12 v the fan should run, sounds as though the fault is in the control panelDHallworth wrote:OK....
On the orange cable (thin one) going into the fan multi-plug there is less then 0.1 of a volt.
David.
Don't be confused by trying to measure a voltage at pin 1. This is just a thermistor measuring heatsink temperature on the regulator. It signals the ECU to make small changes in speed to compensate for heating effects.
Here's a diagram of the blower regulator.
- x 1240
- x 8378
No worries Peter. I've alwas had trouble with PNP transistors; possibly as there was never really a PNP concept in the days of valvesPeter.N. wrote:Sorry Jim, forgot they were PNP transistors
Whenever I look at a circuit diagram containing transistors I mentally relace them all with triodes. I can then understand better how they work....
Just imagine if the blower regulator did have valves in it... No need of a heater matrix for sure....
DHallworth
- x 167
Well I'm going to have another go at this tonight.
I'm getting really fed up with this thing now.
I'm on the verge of calling in an auto electrician. If I could of repalced it easily with another HDi Exclusive this one would be broken by now.
David.
David.
'98 Xantia Activa V6
'00 XM V6 Exclusive
'15 C4 BlueHDi Feel
'00 XM V6 Exclusive
'15 C4 BlueHDi Feel
DHallworth
- x 167
Righto....
On the brown plug that goes onto the blower:
Between the thick red and black pins (supply and negative) there is a solid 14.4v with the engine running.
On the two thin cables, the orange and white ones:
Orange cable to earth: 0.4 volts
White cable to earth: 4.4 volts
Orange cable to white cable: 4.4 volts.
If I bypass the the motor control circuitry the fan comes on at full speed.... I unplugged the red cable going into the motor and the black cable going into the motor, then made a short patch lead to go from the brown plug to the plugs on the motor and it came on at full speed.
I think the fault is on the control circuitry. I tried the ECU (Rectangular valeo box that sits in footwell) from my Activa which I know works an this made no difference.
I have no idea where to go from here now!
David.
David.
'00 XM V6 Exclusive
'15 C4 BlueHDi Feel
'00 XM V6 Exclusive
'15 C4 BlueHDi Feel
Dommo
- x 20
DHallworth
- x 167
- x 1240
DHallworth
- x 167
Well this has got me completely baffled now.
I've got 12v getting to the air con ECU but no signal coming from the ECU to the thin wire that goes into the fan.
When i scan the car with the Lexia it can talk to every ECU apart from the Air Con ECU. I've tried the Activas one which I know works and it's not changed anything.
When I plug the fan in it gives an initial kick but nothing else, this is the same on 2 fan units.
If I short out the fan by plugging it into the feed on the brown plug directly it comes on at full pelt.
For some reason though as soon as I plug it in properly it does nothing.
If anyone locally understands these things and wants to earn some beer tokens I'd greatly appreciate a 2nd opinion!
David.
David.
'00 XM V6 Exclusive
'15 C4 BlueHDi Feel
'00 XM V6 Exclusive
'15 C4 BlueHDi Feel
Clogzz
- x 40
If the fan gives an initial kick, it may be a case of the fan not being able to spin at low speeds.
Slider faults cause a permanent second speed.
Slightly worn motors will run at full voltage, but may not run at reduced voltages for low speeds.
Maybe some ideas here:
http://www.frenchcarforum.co.uk/forum/v ... hp?t=23767
- x 1240
DHallworth
- x 167
Right....
I went out to the car today and plugged the brown into the fan.
It came on at full speed for around 5 seconds and then went off. It did this with the control wire plugged in and unplugged.
I tried it on a spare motor and it did exactly the same.
After 5 seconds have passed the motor stops dead. The only way I can get it to come back on is to unplug the brown cable for a few seconds and then plug it back in again.
Anybody got any ideas? I'm hoping this is the light at the end of the tunnel.
David.
David.
'00 XM V6 Exclusive
'15 C4 BlueHDi Feel
'00 XM V6 Exclusive
'15 C4 BlueHDi Feel
- x 8378
DHallworth
- x 167
