C5 Lighting problems
JohnD
(Donor 2022)
x 72
Unread post by JohnD »
Got a problem with the lighting on my C5. When the lighting switch is turned to the first position:
Numberplate light on, dashboard is lit and the 'lights on' sounder is working.
But both sidelights are off.
Both rear light are off.
A lighting board plugged into 12N socket gives lit rear lamps.
Headlights work both manually and on auto. Also with the wipers.
Surely all four bulbs can't have blown? Some help would be much appreciated.
2010 C5 X7 VTR+Nav 160
1998 1.5 Saxo
1998 Pug 306 1.9D
2018 C4 B7 VTR+
2011 Citroen C1
x 1053
Unread post by wheeler »
The switch & the BSI are obviously working ok so I know it seems unlikely but bulbs really need to be the first things to check & the feed going to them then take it from there.
The bulbs may have failed on by one but you just did'nt notice ?
JohnD
(Donor 2022)
x 72
Thanx Wheeler. I'll start checking. Can't wait to do the front ones.
1998 1.5 Saxo
1998 Pug 306 1.9D
2018 C4 B7 VTR+
2011 Citroen C1
