I have what I think is a fuel filter lighting up on my dashboard, I uploaded an image of what that light looks like. Why is this happening, how can I get this problem solved?
Thanks in advance!!!
Xantia fuel filter light on dashboard???
tonupteabag
spider
- x 77
Would be best to drain the filter (and change it) then unplug it.
For XUD engines, I (just my personal recommendation) say to change this every third oil change (so about every 18K ish) or once a year if you do a low mileage.
Andy.
igor253
Thanks for the recommendation. Just tell me how does that filter affect the preformance of the car? After I change it, will it run better?spider wrote:Would be best to drain the filter (and change it) then unplug it.
igor253
How do you know that? You should change the filter if you didn't by now. Just my recommendationtonupteabag wrote:if its a yellow light on the right side of the dash i have the same problem it keeps telling me there is water in the filter but i know there isn't the sensor is knackered but a new one is £39 so i unplugged it now its not a nuisance
Xaccers
- x 188
Fuel can flow more freely through a clean filter than a clogged one.igor253 wrote:Thanks for the recommendation. Just tell me how does that filter affect the preformance of the car? After I change it, will it run better?spider wrote:Would be best to drain the filter (and change it) then unplug it.
Back when I had 205s with the same dodgy sensor, even changing the filter every 6000 miles didn't stop the damn light coming on.
DIY sphere tool
DIY sphere tool
igor253
So I guess it doesn't relly have to be a problem, it might just be a sensor... Thanks anyway!xac wrote:Fuel can flow more freely through a clean filter than a clogged one.
Xaccers
- x 188
It's such a useless sensor always giving false alarms it was dropped in later cars.
DIY sphere tool
DIY sphere tool
- x 8406
Indeed. About the same time as anti-sink came in. Good thing too.Xac wrote:It's such a useless sensor always giving false alarms it was dropped in later cars.
The sensor works on the principle that water is conductive and diesel isn't. It has two small prongs that stick out into the bottom of the filter bowl and these are about an mm apart. It only needs the tiniest of water bubbles to bridge the prongs and on comes the light.
Diesel naturally has a bit of water in it anyway so the sensor is always going to give false alarms.
No worries at all about leaving it disconnected.
tonupteabag
hi igor i did change the filter the first time the damn light came on thinking that there was a problem checked everything dryed the housing made sure there was no residual water put it all back together and hey presto the goddamn light came on hence unplugged it i now change the filter at 6000mls and i have no hassle
