:( Oh dear
seisporting
:( Oh dear
Unread post by seisporting »
Well it would appear the C%'s clutch is on its way out, 4th 5th and 6th if extended hovers around max torque until car catches up with engine speed then pulls cleanly to rev limiter.
I can sense this could be expensive, probably need DMF at same time, anyone an idea on price C5 mk2 138 6 speed.
x 5672
Had mine done last year, new DMF & clutch plus a few other odds and ends, £399.
seisporting
Where was that at? thats amazingly cheaper than i thought. On the Jag's (same engine) it about a grand!
x 5672
Fraser's in Sunderland.
ETA:
Malcolm (citronut) or Paul (citroenxm) might be able to help out if you are anywhere near them.
seisporting
Ah possibly a bit far then, will have a ring round on monday and give local specialist a call. I really can't be bothered doing it myself on the drive as the weather is appauling at the minute.
x 5672
Whereabouts are you? Edited the above a bit too late :(
seisporting
Eccleshill, West Yorkshire about 4 miles from Bradford.
x 5672
Perhaps someone will recommend an indy local to you. A dealer is likely to be much more that I paid.
seisporting
Oh there is no chance of it going into a dealer for the work, i want it doing properly which is something the Citroen dealer around here seem incapable of.
x 5672
Sadly that does seem to be very often the case.
Our local ones do have a decent reputation but are considerably more expensive than George Fraser. They can do a lot more though, he is old school and has no electronic diagnostic equipment. I imagine that will have to change sooner or later but for now he is first class with pure mechanics and has sufficient work to allow him to disregard the electronic side.
seisporting
I believe that is how my local specialist to be also, should be ok for clutch, just looked on ebay and the kits with the flywheel are £425 :shock:
x 5672
I think he bought mine from GSF but it is a year ago and the price will have increased - he has a discount of course and is very good at charging parts at cost + labour.
Pretty sure it was a Valeo kit.
seisporting
Might see about getting it converted to a stnadard flywheel and a uprated clutch for when it's remapped. Any experience?
x 5672
No but I did consider this when I had my DMF renewed. George had no defined opinion but said he had been hearing of problems with gearboxes suffering reduced life* after the DMF was replaced with a solid flywheel. I opted for the DMF as the one in wasn't completly shot but was close at 120,000 miles and I think my abusive driving style was largely responsible for its demise, I have since adjusted the way I treat it!
*particularly VAG and Ford, PSA not so much.
Old-Guy
x 26
Unread post by Old-Guy »
If you do a search for "Valeo AND DMF" you'll find a number of posts on the subject - the significance of Valeo being that they not only make Citroen original parts and other Citroen after-market spares, but also produce a replacement flywheel/clutch kit for the 2.0HDI that does away with the unreliable DMF. The two drawbacks are 1. drivers need a more delicate left foot; 2. you'll probably have no option but to buy a Valeo clutch plate next time around.
