Ok i have read through the big book of fibs and have got as far as removing the caliper and pads, the disc, loosening the strut to hub mount and also the hub to wishbone one. its still on the wishbone and strut though.
However i am having trouble with the ABS sensor. Is it meant to come out easily or is there a technique to getting it out without damaging the sod?
I'd prefer to get it out and then i can get the car on the road tonight when i finish the other spheres, and not have to get a garage to do it now im most of the way there....
Doing a front wheel bearing on an ABS xantia hatch
KP
- x 27
- x 1489
KP
- x 27
- x 8403
Will,
If this is the front then in my experience, the ABS sensors will come out of the hubs with care and patience. It's the rears that are nigh-on impossible...
Undo (carefullyfully) the 10mm mountiung stud, spray a bit of the old Plus-Gas around and gently tease the sensor out. I use a pair of waterpump pliers to gently rotate it back and forth. The emphasis is very much on the word gently.
It's best really as they are suspectable to damnage otherwise.
The plugs will be found on the subframe. Both are on the bits of the subframe that cant upward at the ends. The RH one is quite accessible but the LH one hides behind the LH inboard CV joint and is a bit of a struggle.
Wheel bearings will need a hydraulic press to extract them despite what the BoL may say
- x 94
KP which side hub are you doing, as i still have a copmplete front hub with bearing and swivle loint as one unit for an ABS car,
brand new OE old stock, i think it is N/S and i would like 45 quid pluss carridge,
i have found Cost Cutters are agents for a national courrier, and will ship packages up to 10k AND 30 x 30 x 50 CM for i think 3.95 or 4.95,
the sender has to take it to there store then the reciver has to collect from a store at there end,
regards malcolm
regards malcolm
KP
- x 27
Cheers Malc
Already have teh bearing, just need to get the hub off and can give it to my nieghbour to be pressed in as he works on loco's the press's should do the job nicely
Will give it a soak tonight once i get home and let it soak in and then can do the other spheres(rear hydractive and ARC sphere) and then have another go at it.
KP
- x 27
citroenxm
- Fallen Hero
- x 70
If the outer race is an absolute SOD, which is likly to be run a ring of ARC Weld in the race, then as the weld cools it shrinks the race with it, making removal Soooo easy...
I learnt that trick from some guys on here when I had trouble removing an outer race..
Works an absolute hoot!!
Paul
Paul
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
- x 94
DickieG
- Monaco's youngest playboy
- x 33
Bear in mind that CT Turbo's and V6's use different front hubs from 'normal' Xantia's Malcolm.citronut wrote:KP which side hub are you doing, as i still have a copmplete front hub with bearing and swivle loint as one unit for an ABS car,
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
