De cat a Xantia 110Hdi
c.morewood
x 55
Unread post by c.morewood »
I've had to start a new thread as I've just discovered that my 90bhp is actually a 110bhp ( I've had access to Citroens DocBackup software)
So I hope the previous thread
http://www.frenchcarforum.co.uk/forum/v ... highlight=
which identified that a 90bhp could be de catted with a -1997 19.TD exhaust was useful for someone.
My question now is, Has anyone de catted a 110? I understand the 90's exhaust is a smaller bore to that of the 110
After numerous repairs to the bend in front of the cat, I've been told "it won't weld again" and is now blowing.
I need a pipe from the manifold to the middle box minimum or I would think about trying to take out the middle box and route to the back box.
Has anyone done that? And can you point me in the direction of an exhaust supplier please?
Thanks in advance,
PS I'm really confused now as I was told years ago by the Citroen dealer that mine was a 90.. I have been insuring it as a 90 as all the insurance sites have it as a 90 .. and now have just discovered a forum that suggests that the Citroen DocBackup service is not always accurate.. is there a visual check I can do to ascertain whether its a DW10 or DW10ATED.... confused!!!!
'00 Xant 110HdiSX Est 83K "W"
'98 Xant 1.9TDSX Est 150K "T"
'97 Xant 1.9TD 20k Est
'94 Fiat TipoTd 40K
DickieG
Monaco's youngest playboy
x 33
Unread post by DickieG »
Mine was de-catted prior to me buying it, it has a straight through section of pipe welded into where the cat normally sits.
If yours is a 110 it will have an intake pipe between the engine cover and air filter as per this photo of my HDi
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
c.morewood
x 55
Ok I guess its a 110 then.
Thanks DickieG
'94 Fiat TipoTd 40K
meexi
Unread post by meexi »
your Xantias not silver is it V112 KOS as that was mine it had 90bhp sx on the documents but was a 110bhp lx
edit sorry just realised it could not have been mine as it had a full stainless steel exhaust on it
2004 C3 XTR HDI 16V 92bhp
2004 Xsara Picasso Exclusive HDI 16V 110bhp
1989 Peugeot J5 Hymer B694 2.5td intercooled 8v 96bhp
c.morewood
x 55
Yes Meexi it is and its V reg, however my V5 doesn't state the Bhp.
'94 Fiat TipoTd 40K
citroenxm
Fallen Hero
x 70
Unread post by citroenxm »
90bhp exhausts do NOT fit 110bhp engines,
The 110bhp outlet is bigger! I know, becuase I tried it.. also de-catting a derv has much less effect then a petrol engine..
The 110bhp xantia here was de-catted before it fell it pieces, never failed an emiisions test yet!
Paul
A very sad...
1994 XM 2.1 d auto
x 1488
You can buy a repair section for the 110 exhaust for <£20, which is the dogleg part behind the cat, it should be possible to buy one of these and cut it and weld it in in place of the cat. This is what I am proposing to do when the exhaust gives out one mine (probably not that far away....) - the single piece exahust inc cat from the manifold to the rear box costs nearly £400 :twisted:
c.morewood
x 55
Thanks Richard,
Do you know where I can buy the pipe?... I've looked through the Bosal catalogue and haven't seen anything.
Cheers,
'94 Fiat TipoTd 40K
rmunns
x 9
Unread post by rmunns »
While I haven't purchased, eBay.de (Germany) has several sellers with Xantia stuff.
x 1488
Here it is on the Bosal catalogue:
HDi 110 Exhahust system
and these guys list it:
Leisure shack
Cat pipe is cheaper than I posted above, but the repair pipe is much cheaper still....!
c.morewood
x 55
Thanks Richard
'94 Fiat TipoTd 40K
Gingerposer
x 6
Unread post by Gingerposer »
I notice your location is listed as near aberdeen - have you tried contacting Reid 4 Speed
01224 586816
53, Cotton St, Aberdeen,
- don't let the name misguide you if you are not familiar with them. I have consistently found them to be very good at sourcing stuff for various cars and priced much better than other motor factors.
Cheers
Ainslie
c.morewood
x 55
Thanks Gingerposter.. not too far from Kemnay.. I'll give them a try.
'94 Fiat TipoTd 40K
c.morewood
x 55
Thanks Guys for all your advice.. just had my first full tank of diesel with no cat... 765 miles to the light.. 60.70lt to fill up that gives me about 57 mpg.. about 5 mpg at least better than with the cat.. and thats only local .. I can't wait for the run to Bournemouth in July.
Thanks again,
'94 Fiat TipoTd 40K
dieselnutjob
Unread post by dieselnutjob »
I decated my 806 HDI (110bhp) years ago.
I just removed the cat / downpipe
sawed out the cat
replaced it with a straight bit of pipe from Partco
To join the pipes I put (from memory) about 8 cuts into the end of each pipe about 1" deep, crushed one end down a bit by squashing the saw cut gap to nothing, splayed the other end out a bit and then rammed one end into the other.
Pipe clamp around each and and the job's done.
On the 806 it's easy because the input and output from the cat are inline and straight.
On my old Passat TDI it was much harder because I had to get someone to bend some pipe to the same shape as the all-in-one downpipe/cat thing.
