Xantia heater is intermittent
Napoleon
x 4
Unread post by Napoleon »
Hi all,
Our Xantia's heater is playing up. Sometimes it simply does not come on, and sometimes it does. So I presume we're talking about a connection problem here, as opposed to a fuse gone somewhere.
Tim
2009 HV09 C5 2.2
1996 N679 Xantia TD VSX estate - sold August 2012
1995 M289 Xantia TD SX hatch - sold March 2012
Tarte au Citroen
2009 24" iMac 3.06GHZ
x 1490
Presumably you mean the heater blower? In which case a forum search on Xantia, blower, and relay ought to turn up a few hits :lol:
Xantidote
x 4
Unread post by Xantidote »
Is it this age/model that has problems with the ignition switch contacts failing, where some members have fitted relay into circuit? As Richard suggests, search the Forum. Think you'll find quite a few posts. Happy reading!
Martin
Napoleon
x 4
Righty-ho, thanks for the pointer.
Tim
2009 HV09 C5 2.2
Tarte au Citroen
x 8409
Theres a good sticky in the "supersticky" all about blowers Tim.
That should make a good starting point...
Ignition switch has to be a suspect, especially if your Heated Rear Window shows up to be a bit dodgy too...
