Hi guys,
I'm sorting out a Xantia '98 1.9td Estate and as I'm not familiar with the ride hopng you can tell me if the spheres are getting old or not.
Suspension goes all the way up/down now I have serviced the front/rear height correctors. It does so pretty smoothly and fairly quickly (well within a minute).
On normal height it rides and drives well, if not super smooth (it's little better than other cars but swallows up road calming humps easily so it's obviously working.
However on the 'high' height (not service maximum high) setting the ride is bouncy as anything, like the suspension is solid.
Does this indicate the spheres on the front are about had it? It is mainly jumping around on the front and I didn't think it should do that unless on full service high where you are not supposed to drive.
Comments welcome, I couldn't find this on a search.
Greg.
Xantia ride quality on normal-high setting
greg123
Tdi VAG mechanic & vegoil converter
Dommo
- x 20
Im not sure how good the ride quality should be on that setting, however I understand you're only supposed to use that setting at very low speeds, to quote the owners manual:
"Intermediate height:
Provides increased ground clearance for temporary use.
For use on poor surfaces at very low speeds."
So that means it probably would feel bouncy at normal road speeds on that setting?
Stempy
Indeed, the intermediate setting is much the same as the high setting and you wont get any suspension travel, it's only there to get you through deep puddles, which is just as well this weather
Lexia ponce
Lexia ponce
marsalek
- x 19
Hi guys,
the mid-high position does not work properly on any Xantia I have ever seen. Even Citroen specialists in my garage could not fix it. So I asked elswhere (Far East, Czech republic
) and got an advice, how to do it.
Here are two pics, what should be changed on the linkage to the both height correctors. Afterwards, one should move the marked metal plates along the linkage, so that the original height setting is kept.
Best regards.
Karel
Source: http://www.citroeny.cz/forumxxx/viewtop ... 7853#77853
Best regards.
Karel
davek-uk
That's excellent Karel. This is the first time I have seen this modification. Something else on the things to do list.
Dave
Dave
Pug Rifter long (20) - 41mpg - Gutsy for a 1.5!
Xantia 1.9 TD Temp.2 Break (97) - 208K@42mpg - Resting again.
Berlingo Multispace 1.6 16v (51) - 184K@36mpg - My shed! Still runs 15° retarded...
Old-Guy
- x 32
Greg
I can confirm that even with new spheres all round, our 95MY 1.9sx Estate is just like yours. The difference between High and Intermediate is a small amount of suspension travel rather than the suspension being locked against the rebound stops.
Karel - that's a very useful modification filed for future use many thanks.
Sid_the_Squid
That is indeed fascinating Karel, in the 5 Xantias I've had the intermediate hight never seemed to be correct, well compared to my previous BX.
I think its worth making this a sticky post.
Gone to the dark side.
Past Citroens
'99 Xantia HDi Exclusive
'99 Xantia 3.0 V6 Exclusive (Green Goblin)
'02 C5 Hdi 110 LX Estate
'98 Xantia 1.8 sx auto with LPG
'00 Xantia Hdi (110) forte
'97 Xantia 1.9D sx
'93 Xantia 1.9D lx (my first) R.I.P
Past Citroens
'97 Xantia 1.9D sx
Dommo
- x 20
Citroenmad
- x 110
You should never drive it in high, as the only suspension you have is the bounce in your tyres. Its only there to help pas through deep waater, steep/high curbs etc. Also handy if hitching up to a trailer etc.
Intermediate is better, if its set right you can confortably drive in this setting, but some cars seem to go to almost high in this setting. This can be adjusted by the above, though obviously normal is where you want to be when driving.
24 Toyota Yaris Hybrid
03 Seat Arosa 1.0S
03 Seat Arosa 1.0S
falling-out-with-my-car
- x 25
Re:
I had to show the manual to a tyre company that thought it was ok to put the car in service height to get the car on the ramps.Citroenmad wrote:You should never drive it in high, as the only suspension you have is the bounce in your tyres. Its only there to help pas through deep waater, steep/high curbs etc. Also handy if hitching up to a trailer etc.
he thought it was ok to drive it in high setting.
- x 1746
Re: Xantia ride quality on normal-high setting
Intermediate-high should be sufficient to climb a service ramp, even with rigid mudflaps fitted.
Component damage aside, traction/grip in Highest can be poor, due to bounce/skip.
