Mot time soon
miggy24
Mot time soon
Unread post by miggy24 »
well i have my mot next month on my 1995 xantia.Is there anything that i should look at before it goes in
Xaccers
x 185
Unread post by Xaccers »
First if you haven't already, check Citroen's website for their free MoT offer and save yourself £50
Check tyre condition and depth (1.6mm)
Check for leaks and anything dripping
Check all lights are working
Check windscreen washer jets are clear and working, and wipers do their job
DIY sphere tool
meexi
Unread post by meexi »
the Citroen`s offer is good but if it fails then you have to get them to repair it that will cost you more than the saving
2004 C3 XTR HDI 16V 92bhp
2004 Xsara Picasso Exclusive HDI 16V 110bhp
1989 Peugeot J5 Hymer B694 2.5td intercooled 8v 96bhp
Xaccers
x 185
meexi wrote:the Citroen`s offer is good but if it fails then you have to get them to repair it that will cost you more than the saving
No you don't.
You can repair it yourself onsite and have it retested for free, or take it away and bring it back and pay the full MoT price, or take it away, repair it and and find a different MoT centre (such as Mr Clutch) that's doing a deal so pay less than the full price.
For instance, in MK Mr Clutch are doing MoT's for £21.
If Cassy fails and I can't fix her onsite so have to take her away, then I'll be giving Mr Clutch my cash. Perrys will get nowt from me.
DIY sphere tool
x 1238
Unread post by Peter.N. »
If its a diesel give it a good thrashing on the way to the test to blow all the soot out of the exhaust system, it should pass the emissions test OK then
meexi
Xac, Would a dealer let you work on a car on there premises?
Xaccers
x 185
meexi wrote:Xac, Would a dealer let you work on a car on there premises?
Depends what needs to be done I would presume, not sure about their legal responsibilities.
As I said, there are plenty of other places which charge less than the full price for a MoT, so use the Citroen offer as a pre-test check and you still save money.
DIY sphere tool
x 94
Unread post by citronut »
i would ask them how much the re/test is going to cost if you took it away to do any work it failed on,
if you take it elsswere it might fail on something diferent to the first time,
as 10 diferent test stations could give you a diferent failure,
regards malcolm
Xaccers
x 185
citronut wrote:i would ask them how much the re/test is going to cost if you took it away to do any work it failed on,
regards malcolm
The terms of the free offer are that if you take it away, you pay the full price for the re-test.
Being cynical, one would expect they'd be going through the car with a fine tooth comb to find failures, so if there are any, they'll find them.
DIY sphere tool
howiedean
Unread post by howiedean »
regards malcolm
My Xantia failed at the Citroen MOT for track rod ends. I had them replaced at my local garage and then MOT'd at the local MOT station. It failed with white front indicator bulbs. :cry: The MOT station wouldnt pass it without them being changed even though the previous failure sheet had no mention of indicator bulbs. To be honest the Citroen garage were fair, all be it expensive for the work they said was required!!
Regards,
Howie
Howie
2006 Fiat Idea Dynamic 1.3 Multijet
2010 Renault Laguna Dynamique tom tom 2.0 DCI 130
C5 VTR 2l 8v HDI Estate 112000 miles gone
Kia Rio 2007 1.5 CRDI 62,000 miles gone
2001 Dodge Durango 4.7 V8 170,000 miles gone
1999 Ford Crown Victoria 4.6 V8 151,000 miles gone
x 5577
Re-tests are free where I take my car and the test is only £30.
