Hi all, once again..
Does anyone know if there is a simple fix for the fuel gauage ?
As having put nearly £70.00 in few day ago, and only having done around a 100 miles, it is now showing just above 1/2 tank, ( my 3 ltr Espace wasn't that thirsty )!, as it's only a 1.8 , this cannot be true !
I seem to remember from previous Xantia ownweship some year ago , that had a dodgy gauage too !!!
Anyone ?
Xantia Fuel Gauage
harryjoe
Xantia Fuel Gauage
1998 Xantia 1.8i 16v Auto (sold)
1997 Xantia 1.9 TD Estate (Resting with 231k) zzzzzz
1989 BX 19 RD (In a barn awaiting TLC)
2002 C5 2.2 HDI Auto Estate (Sold)
1994 XM 2.0 Turbo (Sold)
1983 Bertone X1/9 VS
1995 405 1.8 GLX Estate (sold)
2000 Xantia Estate 2l HDI 110K
- x 1238
Most gauges are non linear and inconsistant, you can only really check by filling the tank to the brim, then doing it again after a few miles and see how much fuel it has used.
The only other thing I can think of is if there is a voltage regulator for the instrument panel that could be playing up, but that would normally affect all the gauges.
Clogzz
- x 40
- x 1238
harryjoe
Hi guys, Thanks for the advice on the solder joints, you wern't wrong, all sorted with the little iron, works a treat,
didn't think the car would be that thirsty
Thanks Once again
Thanks Once again
