Out with old in with new.
lexi
x 133
Unread post by lexi »
V6 Xantia auto fluid. Can you tell new from old?
Been changed twice now. I will change a third time then take a sample. Box is going lovely and whisper quiet.
French Mistresses gone.
Citroen C5 HDI Mk 1 hatchback
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
Sl4yer
Unread post by Sl4yer »
And to think a Cit dealer would never change it... :roll:
Now Citroenless for the first time in 20 years
2008 Mazda RX-8 231
2007 Honda CR-V Auto
addo
Sara Watson's Stalker
x 95
Unread post by addo »
Wow! :shock: Did someone put the wrong fluid in it once?
lexi
x 133
I think it is just heat Adam . Maybe V6 can post some of his recent stuff up that he changed out..........not unless he has painted his fences with it :shock: :lol:
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
citrov6
Unread post by citrov6 »
on my 6 months one it looked vaguely transparent, I'm suprised the clutches last at all in these.
Love my black v6 xant - only one with cream coloured leather too!
lexi
x 133
It must run very hot this tranny......they gave you a gauge to watch. :lol: The transferred heat from that engine as well.
What kind of ATF cooler do we have in these? It aint in main rad is it? Has anyone put a Mocal type one on?
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
citrov6
it is the main rad, there are threads about it and that it leads to the death of the tranny cos its lines cook the deposits into them. it was a good tranny for the time, offering good flexibility while on the motorway, but really its not up to sitting into traffic, fortunately i'm on the motorway most of the commute so its ideal for it.
lexi
x 133
So it`s conventional. We have an auto specific cooling radiator for the engine with the auto section inside and ATF hoses in and out? If that is the case then best option is always to fit an aftermarket Mocal or two with thermostat and bypass main rad OR buy the new Combined engine and auto cooler again........£0uch....these are expensive.
In other trannys the cooler inside main rad can block up at big mileage and kills pressure. I aint heard that mentioned recently on 4HP20............always the filter tray inside tranny itself.
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
DickieG
Monaco's youngest playboy
x 33
Unread post by DickieG »
lexi wrote: What kind of ATF cooler do we have in these? It aint in main rad is it?
The transmission cooler on a V6 sits on top of the gearbox and consists of a heat exchanger between the transmission fluid and coolant.
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
lexi
x 133
Suspected that. So the blockages are actually in the tranny filter tray and not cooler at all. Only pic will be from an engine on the floor ? Can it be seen with air filter off then?
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
citrov6
Sorry my mistake, must of been confusing it with something else.
x 1459
Unread post by xantia_v6 »
lexi wrote:Only pic will be from an engine on the floor ? Can it be seen with air filter off then?
pic stolen from Jim's website
It is the first think you see under the air filter.
x 8389
The coolers are pretty reliable and don't seem to choke up unless, as in my case, the cooling system was full of rubbish from bodged attempts to seal a leaky matrix. The filter stops them getting choked.
Good job they're reliable. They cost an eyewatering sum of money new. In excess of £200 :shock:
That oil looked well used Lexi..
It's easy to see how the filter becomes choked over time as there'll be a lot of dust and debris suspended in that sample, a good deal of which plugs the filter over time.
That oil was better out than in, that's for sure!
The boxes do run hot and this does not help anything. Actually, all the 4HP20s I've stripped to date don't show a huge amount of clutch plate wear. They either seem to be OK or totally wrecked due to something else failing.
I reckon that with regular oil changes and a filter replacement every now and again, the 'box will live forever. They really are a work of solid engineering; it's just such a shame the filter is not easy to replace...
lexi
x 133
Ah ...that`s a good pic of cooler. It also looks like a great place to tap in and out for a proper transmission flush should I ever feel like splashing out on the Esso again :shock: Or is that just the water lines we see? Where are the ATF feeds?.
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
