Nice one with the dirty contacts in the drivers side electric window switches they are now working perfectly both up and down.
c5 temperature reading
mrlogik
reading for mixture
I didnt mean for glow plug operation at all i meant for fuel air mix as this changes slightly with outside air temp being such a large range.
c5 hdi 110 lx
Xantia hdi forte 140,000 [sold]
- x 5582
civvie
- x 21
- x 1044
Yep, the Outside air temp sensor has nothing to do with fueling or running of the car (did you notice the car running any differently ?).civvie wrote:Wheeler,
You trying to tell me that garages tell porkies!!
Steve(':roll:')
It can however effect the operation of the A/C.
The glowplugs use engine temp info from the coolant temp sensor.
The Fueling/running uses info from both the coolant temp sensor & the intake air temp sensor which (as myglaren says) is a part of the MAF sensor, well on the HDi's anyway.
