My aircon went just before xmas. I say went, but it was still connected to the drive permanently for some reason so the bearings went and it is still whiring away whenever the car is driven so Ive limited that to short journeys.
What I think I need to do short term is switch to a non-aircon belt, that way I can have it de-gassed and drive it without the pump turning. I'm thinking one of the belts from a non-aircon will work for this. Not sure what the roller layout is with non-aircons if this is a workable idea
non-aircon v6 aux belt
citrov6
Love my black v6 xant - only one with cream coloured leather too!
citroenxm
- Fallen Hero
- x 70
Non Air con V6??
In this country, werent they ALL equpit with air con? My guess is, you have to hazzard a guess at the Length of belt and then specify the length needed rather then the application you want..
paul
paul
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
- x 8400
citroenxm
- Fallen Hero
- x 70
citrov6
- x 8400
Been out, braved the cold and came up with this:
This shows the routing that should work. The belt shown is too long.
I reckon, using a tape measure in place of the belt, that you'll need a 6PK1420 belt although you may need to experiment with belts around the 1400mm length to find one that fists best and will tension acceptably.
This Dayco catalogue page shows all the 6PK belts available.
Any good factor should be able to supply a 6PK belt by size, alternatively, take a tape measure to your local Halfrauds and measure their selections...
Hope that helps a bit.
citroenxm
- Fallen Hero
- x 70
- x 8400
citrov6
- x 8400
Yes it doescitrov6 wrote:I take it the designation 6kp1425 means length 1425mm
the 6PK bit means 6 "peaks" or rows on the belt and the number is the length in mm...
Halfrauds belt part numbers are similar in that the length is in there. They usually number something like HB1130g
citrov6
citrov6
I did measure the path later that day it was 140mm shorter than the original and cut across between the alt and crank pulley missing the aircon. So I ordered the closest belt a 1472mm and it was a bit tighter than the 1623mm that Jim recommended as standard replacement but has some give, the tensioner compressed quite a bit but it looks like it is working ok
- x 8400
citrov6
citrov6
Sorry to bring this thread up again.
I'm going to fit the aircon back this weekend hopefully and was wondering if its a 1625mm or 1620mm Dayco belt that was recommended by CitroJim. I can't find the thread where its mentioned.
I think it was a 1625mm and the tensioner was extended quite far to keep its tension but easier to put on than a 1620mm
Then that should be it, spheres, heater blower, drivers window regulator and it should operate like a semi normal car like before
