C5 SIDE LIGHT KEEPS GOING
reacher
Unread post by reacher »
Happy new year everyone, as the title suggests, the side light bulbs have been replaced five times (by myself) in the last few months. Changed the off side one two weeks ago then two days later the other went, changed that and its gone again after a week. Wondering if its crap bulbs from Halfreuds(£5.35each). My hand book spec is for capless 5w but the bulb holder is for a bayonet fitting and they only do a 4w or 6w so have been using the 6w, cant see them blowing with one w less than spec but dont know. anyone got any ideas as its driving me daft and costing me as well! :roll:
55 1.6 Facelift HDi LX C5 Hatch
Reacher
Citroenmad
x 110
Unread post by Citroenmad »
Ive had to replace three on our facelift C5 now, very annoying as they are not the easiest thing to get at are they. I bet its cheap bulbs, some last no time at all.
They use a funny little bump, offset pins not capless. Quite hard to find from some places actually. I just went to my local motorfactors and get a few for a few £s
24 Toyota Yaris Hybrid
03 Seat Arosa 1.0S
Trainman
(Donor 2018)
x 43
Unread post by Trainman »
Had a similar issue with my C5, and found that a lot of the time, it was a loose connections on the wires to the bulb holder and not the bulbs themselves. :(
Steve
http://c6owners.org/index.php
citronel
Unread post by citronel »
I had a similar problem on both cars: C5-II 1.6HDI until one day I decided to change it with LED's strip. I succeed to modify it myself without removing the headlight.
It is almost 1 year since then and no more problems... well maybe the front driving lights that I have to change one bulb at ~6 month but I admit I buy the cheapest one I can find because now I have experience changing it in short time.
I can't describe you how good it look in the night:
reacher
Citronel, those led lights look great, I was thinking of maybe converting to led but not thought of a whole strip. They do look good. Might try getting bulbs from somewhere other than Halfrauds.
Its the bulbs that are blowing so its not loose connections.
Thanks everyone.
Reacher
x 5674
I have seen them advertised on eBay.
Citroenmad
x 110
They do look very nice, but how do you get the strip inside the hole and sort it out where it needs to sit etc. Its hard enough changing the bulb :lol:
03 Seat Arosa 1.0S
x 5674
Citroenmad wrote:They do look very nice, but how do you get the strip inside the hole and sort it out where it needs to sit etc. Its hard enough changing the bulb :lol:
Dead easy - take the front off the car :twisted:
Actually the 'bumper' (no it isn't!) comes off without much bother.
Except it is far too cold for those shenanigans right now, or I would do something about my washer pump - maybe :roll:
citronel
I succeed to put the LED strip inside headlight without removing anything except old bulbs ( of course battery and protector from right ).
This are SMD LED's on flexible strip and first time it took me ~1h to fix the strip in place and fix it in position.
reacher
Citronel LED
Citronel, I am very impressed with your LED side lights and would like to do the same to my C5. Can you tell me where you got these lights, what length (size) and as much detail as possible. Did they come the right size or did you have to cut to length? I have been looking for some and have seen some that can be trimmed to length. :?
Reacher
citronel
30 SMD LED's on flexible stripe with silicon insulation.
length: ~30cm and no need to cut from them.
I had to cut only part of the insulation at the first 5-6 LED's to enter properly on small space.
here its the package:
reacher
LED
Thank you very much Citronel, you have been very helpfull. I should now be able to do the job, that was a quick response!
Happy New Year!
Reacher
Reacher
reacher
LED
I want to thank Citronel for all the very good advice and details about fitting LED strip lights in place of old side light bulbs. I have now done mine, it was quite easy and only took about an hour or so out in the freezing weather! They look really good and give the car a distinctive look. The LED strips only cost me £9.00 on ebay including delivery for a set of 2 - which is cheaper than 2 normal bulbs from Halfrauds (and they dont last very long) so I'm really pleased with them, I would recommend anyone to fit them with this type of Headlight.
Thanks again Citronel.
Reacher :lol: :D
Reacher
citronel
Reacher;
Welcome in Citroen New Look - LED Club. :lol: :lol:
For full membership of course we expect pictures. :lol: :lol:
reacher
I have not got to gripps with putting photos on the site yet but will try.
Reacher
