I have a strange electrical problem on my Xantia and was hoping somebody on here might be able to help.
When the key is in the ignition but engine is not running, i am able to run the heater blower and the rear heated window.
Once the ignition is turned and engine is running, neither will work.
Although this is one of those intermittent faults so sometimes it works fine. (just like the rev counter and rear wiper, but they dont worry me so much!)
Looking at the Haynes manual we have found both the rear window heater and blower are earthed at B002 earth equipotential post and think this could be the problem.
But where is B002?
Any help with this would be really appreciated.
Some more info which might identify the cause.. Recently changed the "Clutch Clip" and also had some leaking problems in the boot(I think it was the rear light cluster).
Xantia Electrical Problem with heater blower+rear window
Xantia 1.9TD Owner
DickieG
- Monaco's youngest playboy
- x 33
A faulty ignition switch should be your first port of call, a quick search of the forum will bring up loads of posts on the subject and also how to fit a relay to overcome the issue.
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
Xantia 1.9TD Owner
Clogzz
- x 40
Welcome to our troubles, X19O.
B002 won’t be the fault; and don’t know where it is because I’ve never had cause to explore there, but it’s always there irrespective of switch position.
If you only got the car recently, there’s the possibility of a bodgie in the switch wiring, like a dubious splice of the switched blower wire to a permanent live.
The ignition switch can be parted from the barrel, so as to replace it from a wreck while keeping the same key.
Whatever the finding, the only permanent fix is a relay to feed the blower.
If wetness in the boot starts from a corner, then it’s usually water leaking past the cluster seal.
The cluster may have been left loose after a bulb replacement.
Xantia 1.9TD Owner
Hi Clogzz
Yes you're exactly right about the wet boot corner. Although im not sure if its due to the cluster being left loose, as i always tighten it well and the rubber seal seems ok.
I think it could have been simply down to the snow sat on top allowing it time to get through.
This time was the worst ive ever seen it, previously it was just a small wet patch on the right hand corner of the boot after heavy rain.
I did have an ignition problem a while back (maybe 2 years now, owned the car since 05) and had a replacement fitted. Pretty sure it will have been an old one from a wreck, like you say.
I'll look into a relay feed to the blower, its certainly a bad time of year to be without it!
Thanks for your help
Clogzz
- x 40
Hi X19O,
Water coming in through the cluster can be a fiddly repair job.
I thought that mine was loose, so retightened it while wriggling it in … and it still leaked.
The sealing surface in not perfectly flat, with the looks of spot welds or something.
There is a trail of grey dust where the water leaks past the seal.
Maybe that the seal has deteriorated in time, but certainly not in a visible way.
In the end, I slapped goo along the top part of the seal, and it’s kept the rain out since.
All the water from the rear hatch, and also much from the roof is dumped onto the rear light clusters.
You may see water sloshing around inside the cluster, as I had, and next the cluster earth connector was corroded, causing the turn indicator and brake light to go dim.
I soldered a piece of wire around the earth connector, and it’s been good since.
All ignition switches of that vintage have packed up because of the high blower current.
A replacement would have to come from a Mk II with relay modification.
Waiting for the wild weather to end, you could temporarily feed the blower from the cigarette lighter, and unplug when you switch off.
Old-Guy
- x 26
Last winter (intending to be prepared if I had the dreaded blower/HRW problem), I collated various useful posts into this complete how-to-do with circuit diagrams and pictures. This might save you a lot of searching.
- x 5673
Xantia 1.9TD Owner
Xantia 1.9TD Owner
Just had a quick read over the pdf Old-Guy posted.. thanks that is a really well put together guide explaining everything.
And Clogz.. ive checked my rear tailight and it has let some more wet in. Even though i cleaned up the seals and tightened it as far as it would go.
So its time for some modification!
