Melted battery lead (Urgent)
lexi
- x 133
I remember there was a whole load of Alternators frying batterys a few years back. Lets just say it was a factory in Wales
Least you got to the bottom of it although a bit more costly than a loose Earth.
French Mistresses gone.
Citroen C5 HDI Mk 1 hatchback
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
deian
After seeing those photos I would say the alternator needs a new regulator. Thats mad damage, I wouldn't run it until the problem has been sorted tbh, incase the battery explodes.
The battery is just the buffer between the cars electrics and the alternator, and most items can run at over the 12v needed (batteries output to 14.4v usually), because the battery will dampen the current it's voltage won't go too high, but the current into it will, hence the melting. Ouch.
To be on the safe side afterwards, get a new battery.
- x 8401
Yes, it may seem Ok but it'll die soon. Many years ago I had the regulator go short circuit on my Renault 4 and that boiled the battery despite the car only having a little dynamo. I only knew it had happed by the smell! The dynamo was red-hot and the battery fairly seethingdeian wrote: To be on the safe side afterwards, get a new battery.
Anyways, the battery survived for two days afterward and then, nothing, not a sausage...
Xantidote
- x 4
Well, new battery, replacement alternator, and new cables in vicinity of the battery. Hopefully the other cables/wiring are OK as no fuses blew. The high voltage may have shortened the life of any bulbs that were on at the time.
On the bright side, you've not got a bill for breaking down on the motorway and having to be towed home -
Martin
1995 Xantia TDLX (deceased
deian
Xantidote
- x 4
deian
scoles
thanks for that guys looks like i found the problem.
I was aware that petrol regulators ran at 14.4 volts but wasnt sure if the diesel ran higher to compensate for higher cranking amps or such.
Is it possible to replace the regulator on its own? if so where can i find it?
Also how am i able to prove for a fact that this is the problem?
Cheers
Stuart
Cheers
Stuart
deian
if when you test the voltage across the battery at rest it would probably be around 12 or 13v, if when you start the car, the alternators provide the power and recharge the battery, so naturally if the voltage is higher across the car then it would show this on the battery too, so something on the alternator isn't regulating the voltage output.
as for whether the regulator is changeable is dependable on the alternator, MAYBE if you have some details of the exact car and year, someone may be able to tell you which alternator it has and therefore whether the regulator is interchangable
scoles
- x 1240
The regulator is obviously the problem, what's happening is that the alternator is running flat out, it would probably only be a short period of time before it burnt out. A secondhand alternator would probably be the cheapest way. There are new ones on ebay from about £30.00 but you would have to check suitability. You could probably get a new regulator but it would probably cost as much as a s/h alternator
deian
bxman
subject
I am intrigued by the sugar like granules in the photo.
Are they small balls of copper?
It looks like a dry/loose/high resistance battery connection that could well have been sparking for some time. I suspect the intermittent loss of battery connection (capacitance) may have caused the regulator to short out whatever else no-one can say the alternator and it's belt were not up to the job.
If you post a photo of the regulator and PM me your address I will willingly send you one for the cost of the postage.
Off subject for a second can anyone explain why the second page of this post fits my screen while the first one does not.
Good Luck, Thanks and a Happy New Year to everyone
Patrick
Assorted Xantia
Patrick
Assorted Xantia
scoles
Re: subject
Hi thanks for the input bud,bxman wrote:I am intrigued by the sugar like granules in the photo.
Patrick
Assorted Xantia
I thought the regulator on these couldnt be replaced and in fact it had to be the whole alternator unit?
Cheers
Stuart
