Heated wing mirrors
Martin Beevers
Heated wing mirrors
Unread post by Martin Beevers »
Hi,
Just a quickie, On my wing mirrors I have a couple of wires attached to the back. I presume these wires are for heating. But I can't find a switch to turn them on.
Do they come automatically? Or do they come on when the rear windscreen heater is switched on?
95 Xantia 1.9TD SX - Now sold
x 8391
As far as I know Martin, they come on with the heated rear window.
citroenxm
Fallen Hero
x 70
Unread post by citroenxm »
Confirmed!
The operate with the rear heated window..
Paul
A very sad...
1994 XM 2.1 d auto
Martin Beevers
Yeah, dumb question. :oops:
I found the answer in my handbook...
Mine don't work, the rear window works fine tho, which counts out the fuse.
I've had them off a few times. Does it matter which way round you have the wires? (Another dumb question.)
admiral51
(Donor 2026)
x 391
Unread post by admiral51 »
I dont think it really matters which way the wires go. I have just replaced the drivers side mirror on my VSX and i had power to the leads but no heat so i assume that the heating element has given up the ghost :)
Its worth checking that you have power at the wires as it may be you have a break somewhere in the inner door loom.
Stating the obvious but you need the engine running for the heating element to work
Colin
DickieG
Monaco's youngest playboy
x 38
Unread post by DickieG »
Martin Beevers wrote:Mine don't work, the rear window works fine tho, which counts out the fuse.
If that's the case clean up the connectors on the back of the mirror glass as they do suffer corrosion, failing that and you have 12v there it'll be the mirror glass heating elements which do become less effective over time.
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
rmunns
x 9
Unread post by rmunns »
Do all cars have heated mirrors? Mine (year 2000 Hdi90) doesn't seem to have heated ones. HRW works fine.
Martin Beevers
Not sure,
To check take the mirrors out, and if you have 2 wires attached to the back of them then I would say you have.
DickieG
x 38
rmunns wrote:Do all cars have heated mirrors? Mine (year 2000 Hdi90) doesn't seem to have heated ones.
Generally speaking those equipped with electric mirrors were also heated, especially on S1 models.
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
