V6 starting probs
x 1463
Unread post by xantia_v6 »
lexi wrote:Terminal 87a on that diagram? is that earthed or not used?
Not used
lexi
x 133
Unread post by lexi »
Thought that V6. Wired that up today. Mmm.....starter dead :lol: :lol:
I have taken the power for relay from the white wire at the 2 pin plug on AC Comp. There is a green wire alongside it. Will check in and out with meter tomorrow. Then check for possibility of Solenoid sticking. Horrible cold NE wind atm :evil:
French Mistresses gone.
Citroen C5 HDI Mk 1 hatchback
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
x 1463
I am not going outside to check, but I think you may have taken your power from the AC clutch. The solenoid wire has a 2 pin connector, but only one pin is used.
lexi
x 133
Thanks V6 will check that out..........tomorrow !
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
lexi
x 133
Taken relay et all out again and simply hard wired it back in with some heavy wire. The relay and fuse etc would maybe have been an issue to renew in those positions on a cold dark night . There was also the heat issue. All Ok atm.
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
