Xantia 1.9TD with a stiff clutch
lexi
x 134
Unread post by lexi »
Then just what has it got in it then Lexi
Aloe Vera with no wrinkles :lol: :lol:
French Mistresses gone.
Citroen C5 HDI Mk 1 hatchback
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
AbangCorp
Unread post by AbangCorp »
i have this experience
after i change my engine to a good used one
it sure is stiff but after that, my leg does not feel it anymore
i do think that my leg is stroger now
x 94
Unread post by citronut »
copper slip/grease is realy for use were there is high temprature, i always smear a very little trace on the gear box input shaft splines and thrust bearing guide tube/sleave,
also i have always been told nylon is self lubricating
regards malcolm
x 1238
Unread post by Peter.N. »
It made a world of difference on one of mine when I oiled that top bearing, could have been of course that the shaft was corroded.
Chris570
x 37
Unread post by Chris570 »
a new symptom, when the suspension is in high the clutch is very light.... its got to be the cable surely?
cheers
x 1238
Very odd, the clutch cable shouldn't be affected by the height as one end is fixed to the bulkhead and the other to the gearbox, the cable shouldn't move. The only thing I can think of is that something connected to the suspension is fouling it.
Chris570
x 37
hmmm, i cant think what could be fouling it (forgive me if i'm wrong here) but isnt everything that moves (track rods, driveshafts and arb) way too low?
x 1238
I would have thought the same but there must be some physical connection to cause the symptoms. Is the improvment progressive ie the higher the lighter?
Chris570
x 37
between med and low it makes no diff, i'm thinking getting the air filter off and having a butchers is the way forward on this :)
x 1238
The nearest thing I can think of is the top of the drop link/anti roll bar
deian
Unread post by deian »
I have a stiff clutch too, i will have to try putting my car on high and see if it lightens up.
Having said that lubing it up should help as I have that plastic cover over the bell housing, so the clutch mechanism has never seen the light of day before.
Do you know if you have that plastic cover over the bell housing under the airbox? That plastic cover has put me right off lubing the clutch for the time being. But now i'm off for xmas i have the time for mess about with it.
Let me know how it goes chris. Ta
lexi
x 134
If that autobox throws its toys out of its pram
Then I will be throwing the car right out after it :shock: :lol: :lol:
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
Kowalski
Unread post by Kowalski »
citronut wrote:copper slip/grease is realy for use were there is high temprature, i always smear a very little trace on the gear box input shaft splines and thrust bearing guide tube/sleave,
regards malcolm
You get oil filled nylon, which is nylon with oil added as a filler, that self lubricates but the oil can disappear with time, so adding more oil will improve it if it dries out.
Old-Guy
x 22
Unread post by Old-Guy »
In fact it's much more complicated that that! Materials that are generally referred to as nylon, as in nylon bearing, may well be some other engineering plastic - even when white! Then there is a bewildering range of nylon grades, many of which can be filled with a host of materials: glass powder and fibres (glass-filled nylon), 'inert' fillers like chalk and talc (both mildly abrasive), solid lubricants like molybdenum disuphide ('moly'), graphite and PTFE (Teflon), 'solid' mineral lubricants (greases), liquid lubricants (silicone and mineral). To confuse the issue, some of the self-lubricated plastics products are covered by patents and have proprietary names.
If you're curious have a look at RS components Engineering Components pages.
x 1238
I remember them when they were 'Radiospares' had a little trade counter just off Tottenham Court Road :( :?
