C5 particle filter additive ???
john alexander
- x 5672
john alexander
- x 5672
- x 1055
You don't/can't pressurize the suspension system with Lexia. The only time you pressurise the C5 suspension circuit is to bleed the power steering circuit & you do it with a coolant pressure tester pump & cap adaptor. They system pressurizes itself a little & you normally get a little hiss when you take the cap off.
- x 5672
john alexander
john alexander
- x 5672
meexi
- x 94
meexi
stevo31
- New User
Re: C5 particle filter additive ???
I have a Citroen C4 Pissaco 1.6 automatic. what type of additive is used in the partial filters. In previous posts in this forum it mentions upstream and downstream flows into the fliter what does this mean
Thanks for your help stephen
- x 5672
This could depend on the age of the car - originally it was Eolys, one of two different and incompatible types but I believe there are further developments of the fluid.
Your post moved to this thread as it is more relevant to your question.
Welcome to the FCF
Welcome to the FCF
- x 3565
This should give details of what additive goes in which vehicle:
http://www.frenchcarforum.co.uk/forum/v ... =3&t=50195
