Will HP fit 2.1TD?
- x 1240
DickieG
- Monaco's youngest playboy
- x 33
MikeT
- x 232
- x 1240
MikeT
- x 232
I think I've narrowed it down to;
4007S7 (if it came from a sinker)
4007T5 = XUD9 w AirCon RP 06445-07620 / XUD9TE RP 06445-07620
4007T7 = XUD9TE RP 07621 onwards
I've been informed the 2.1TD requires a T7
Having just looked through some emails, I found out some more details about the donor..... REG P934 ECF REG 27 03 1997
Can anyone narrow down the selection above from this? Thanks.
MikeT
- x 232
DickieG
- x 33
MikeT
- x 232
- x 8437
Mike,
So far as I can recall, the 2.1TD pump is very similar to the 1.9TD as it's mounted in the same way and in the same position. Therefore it should swap but where you may come unstuck is with the threads oin the delivery unions.
I'm sure Martin @ Pleiades will be able to confirm one way or another.
Pleiades
Wrong !!!
Martin @ Pleiades does not know
The problem is that there are lots of differnt pumps, they are all the same basic pump (except V6) There are just some very suttle differences and looking at Citroens web pages you cant realy make much sence of it all.
The differences come as, Pulley size, distance from the edge of the pulley to the pump (this will make the belt run off if wrong) and on some pumps the pulley is put on back to front, whilst on others the pipework is not in line.
Down to basics and if the pump fits and the pulley is in line and the belt fits, then it will do the job as all of the pumps (except V6) are the same inside.
If I had the pump in front of me on a bench, then I could tell you what it would fit, but from a picture it is not possible to tell as the differences can only be a matter of a few mm.
Regards.
Martin.
Regards.
Martin.
MikeT
- x 232
