Hi
I am sorry this question is duplicated but it was in threads named clutch.
I removed the plastic brake canister that sits behind the brake pedal to change the clutch clip and I cant seem to get it back in.
Can someone please confirm that the open end pushes in to the rear of the brake pedal and the solid end touches the floor.
Is it a very tight fit cause it doesnt seem to want to go in?
cheers
Howard
Where does the plastic brake cannister go?
NiSk
rs1800
Le-Mans
That's what I had to do with my one too - Cut slots in it. You needn't worry about the slots rendering the unit unsafe. It's fine.
Unfortunately, I managed to snap the large plastic ring-clip that holds the canister in place, just as I was pushing the canister home. So I just used a bit of tape to hold that together and tested the whole thing. All fine. The canister can't come out unless I lift the pedal as high as it will go and pull hard on the canister.
By the way, I think there must be some way to remove the entire canister assembly from the pedal, because after I took the main center part out, I noticed that the base part of the assembly could slide in and out (like telescopically) of the pedal but not all the way out.
alexx
Le-Mans
alexx
On mine (LHD), pushrod connected to the brake pedal is made of steel, about 5-6 mm in diameter. As I said, it disappears through the hole (about 1.5 cm diameter) in the floor. I can see some white plastics inside that hole (probably the canister containing that spring), but can't withdraw it from the cabin. Rubber cap of doseur valve isn't visible, like it was in BX and GS (directly under the pedal).
So, is this different on RHD models? On the picture in Haynes, I can see that brake pedal lever is different than in my car (considerably wider), where it looks almost like mirror image of the clutch pedal.
I was planning to remove that spring after buying Xantia, to get BX-style brakes, but it seems it's a bit more complicated here.
JohnW
Strange. Mine just pulled out from the socket in the pedal (RHD, 1995, 2.0) and there was no possible way of confusing which way round it fitted. And it pushed back in without trouble.
I suspect they had several "goes" at this design. Terrible thing anyway - I replaced the spring with a nut and the brakes are much nicer.
JohnW
JohnW
alexx
rs1800
