New Xantia hdi owner.. engine light on though :(
seany87
Unread post by seany87 »
Hi there Citroen people!,
Ive recently acquired (for the princely sum of £0!) a tidy x reg xantia hdi 90.
however the engine light is permanently on, but performance seems fine.
what might be the issue here? I.E what can I check on it, perhaps a sensor? (if so which ones are the likely culprits)
Thanks for the help to a newbie guys!!
citroenxm
Fallen Hero
x 70
Unread post by citroenxm »
Welcome!
It can be a FOREVER guessing game with the light on in a HDi engine!
You REALLY need to get it connected to a Code reader and have the ECU Fault codes read off, you could be chasing a fault forever!
Paul
A very sad...
1994 XM 2.1 d auto
seany87
Cheers!
hmmmm, Im guessing that its going to cost the earth to get it plugged up and looked at though? Any idea how much a dealership would charge in comparison to a specialist?
rory_perrett
Unread post by rory_perrett »
Not sure it is a lot of use to you but I bought a 110 Hdi last year. Done 37,000 miles in it since and it runs fine. However I suspect that the engine light will be on all the time as the bulb has been removed. If I ever have to take the dash out for another reason I will replace it and see, but life's too short otherwise. If it was on all the time I would have probably have taken it out by now myself.
citroenxm
Fallen Hero
x 70
Anything around the 60 odd quid for a read, much better with an Indy..
Paul
A very sad...
1994 XM 2.1 d auto
x 8406
That's a lot of money for plugging in a Lexia :twisted: :twisted:
Have a look at the Lexia sticky and see if there is anyone on here near you with a Lexia who might do a diagnostic for you Sean.
As all seems OK, it'll only be something minor but the MOT man may object to it come MOT time.
x 5672
Can I take this opportunity to reiterate the request that any willing Lexia owners froward their details (Postcode an willingness to read other member's cars, any limitations) so we can post a map of where each one is located, as per the Citroen Relay model.
Send details by PM rather than on an open forum.
I will only post an approximate location rather than a precise one, anyone wishing to avail themselves of the service can then take contact via PM or email and make whatever arrangements may be necessary.
seany87
cheers guys
good to see that theres plenty of help on forums for older cars as well these days!
