Towbar electrics - Xsara P2
Will
Unread post by Will »
Hi
Just bought a Witter towbar for my Xsara - a 2003 model. It came with a 'standard' electric wiring kit - by the looks of it you just tap into the rear loom to take power as per cars from old.
However, is this correct? The place I bought it from said it would do the trick but I've also heard that later P2's need a bypass box as they are multiplexed?
I'm confused! Any help would be appreciated! :)
Will
2008 C5 HDi 136 VTR+
1991 AX GT
1983 2CV6 Beachcomber
1979 2CV6
1974 AZU250 Belgian PO
x 1053
Unread post by wheeler »
Thats correct, the wiring will just tap in as normal to a multiplexed xsara with no problems.
Will
Thanks for the info.
Is there anywhere that details which wire colour is which on the car loom or is it just a case of trial and error with a meter?
Cheers
Will
1991 AX GT
1979 2CV6
x 1053
Easiest way is a cheap test lamp & prod the wires.
Anyway, never go by wire colour on newish (post xantia) citroens, always go by the number printed on the wire & pin position, colours quite often change & in some cases there are connectors that have loads of wires the same colour.
Xantidote
x 4
Unread post by Xantidote »
Would it not be possible to make the connections at the rear lamp units? Saves messing with a meter. On my Xantia, I made most of the connections at the rear lamp units, as I don't like those connectors where you squeeze them on to the cable at any convenient point.
FWIW, on one of the BoL's Xantia wiring diagrams, I came across a 12v power feed shown, which I discovered ended in the car at a socket hidden behind the offside boot interior trim. Used this for permanent 12v supply for tent lights etc. :)
Martin
uncle buck
x 10
Unread post by uncle buck »
Here you go....
2001 Xsara II 1.4 LX
x 1053
Xantidote wrote:Would it not be possible to make the connections at the rear lamp units? Saves messing with a meter.
Yes thats the ideal place to make the connections, but how do you know which wires to connect the towbar harness to on the car without checking them with a meter or having an accurate wiring diagram ?
Uncle buck: I think he meant the wire identification on the cars wiring not the trailer sockets.
uncle buck
x 10
wheeler wrote:.....Uncle buck: I think he meant the wire identification on the cars wiring not the trailer sockets.
I'll get my coat.... :lol:
Will
Thanks for your help guys. Its appreciated.
I'll take the feed from the rear lights as suggested and I'll also check each one to make sure it goes to the right place!
Will
1991 AX GT
1979 2CV6
leithant
x 9
Unread post by leithant »
Apologies for hijacking, but should I do this on my Xantia too?
06 Citroen C5 Estate 2.2 Hdi Auto
95 Peugeot 306 S16
95 Silver Xantia VSX - now deceased :-(
