I remember on last HDI Estate someone had put tiny discs on the front. The pads then only made contact with half of their swept area. That
resulted in about 20 per cent braking on Mot test (50 allowed).
Will strip out to look but my 1.9td estate has bigger rear discs than these!
I assume the fronts will be the big disc same as HDI? Any info on proper rear disc dia on Mk1 V6.?
