HELP ME WITH MY CENTRAL LOCKING
reacher
Unread post by reacher »
On my C5 every time I press the key fob to unlock the car the boot pops open and so I have to shut it before getting in! Then when I arrive at my destination I cant open the boot without first locking and then unlocking the car. Have tried sycronising the key fob by removing then replacing the battery, then inserting in and turning on ignition then pressing the lock button - nothing happens, its getting me down! That and the fan keeps coming on but thats another story! :cry:
55 1.6 Facelift HDi LX C5 Hatch
Reacher
Xantidote
x 4
Unread post by Xantidote »
Ah, the joys of (failing) modern technology!!!!
Martin
reacher
:roll: Yes thanks for those words of wisdom, I bet someone knows how to cure it :wink:
Reacher
Cyprian
(Donor 2021)
Unread post by Cyprian »
My boot lock works OK, but every so often the drivers door stays locked while all the other doors unlock. It does other weird things too, like the rear drivers door will not always open from the inside. I have just accepted it. :roll:
reacher
:roll: I see, I am not at that stage yet! :roll:
Reacher
x 5673
Cyprian wrote:My boot lock works OK, but every so often the drivers door stays locked while all the other doors unlock. It does other weird things too, like the rear drivers door will not always open from the inside. I have just accepted it. :roll:
Give it a firm pull, then it will open.
Spray the catch with silicon spray, lasts for about six months.
reacher
thanks myglaren, will try that to open the boot.
Reacher
x 5673
reacher wrote:thanks myglaren, will try that to open the boot.
Never had a problem with the tailgate but the driver's door is often awkward.
If it won't open from outside a firm push (to close it) will allow it to open.
reacher
Tried the firm pull but it dont budge! its locked! got to lock then unlock!
Reacher
x 5673
I thought mine was locked too and was entering/exiting through the passenger door.
Try some WD40, although it doesn't last more than a couple of days.
If it is locking there must be an electrical fault, probably the wiring running into the drivers door. Odd that only the one door locks though.
reacher
no its only the boot that is locked when all other doors are open, or the boot pops open when I unlock the car.
Reacher
x 1939
My C5 goes through phases when the boot lid pops open when I unlock the car using the remote. It will also open when I open the front door from the inside but I've not had the problem of it refusing to open until you go through through the remote lock/unlock rigmarole.
The only comfort I can offer is that in my case it only lasts a few days and then behaves itself for a few more months. Has yours done this for a long time or is it a new occurence?
C5s are known to be sensitive to failing batteries but in my case it's been doing it for a few years now!
reacher
its been doing it now for a few months. might try disconecting the battey. :roll:
Reacher
