Faults on my to do list !!!
addo
Sara Watson's Stalker
x 95
Unread post by addo »
MJM, thanks for the comprehensive rundown on drier life expectancy. It was very informative and will help some of my decisions.
Cheers, Adam.
HDI
x 7
Unread post by HDI »
I can tick two off the list :D
1/ Suspension going intermittently hard.
2/ Loss of power / limp home mode.
3/ Aircon not working.
4/ Headlamp washers not working. ( _/ ) *** NOW SORTED , WAS THE PUMP RELAY , 4 SOLDERED JOINTS FRACTURED !! ***
5/ Heated seats not working on 1st two settings.
6/ Find a front undertray.
7/ Sort out various brackets and pipe supports under the bonnet.
8/ Replace oil temp / oil level sender.
9/ .......... I'm sure there was something else , errrmmm ! Ah yes , weak ventilation !! ( _/ ) *** NOW SORTED , POLLEN FILTER !! ***
Only 7 to go then !!
Now using '00 Xantia LX HDI, pov spec :(
My past Citroens :-
'00 Xantia SX HDI, now dead due to accident :(
'99 Xantia HDI 110 Exclusive, RIP :(
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
'79 CX2400 Pallas (scrapped :( )
& a couple of Peugeots !
HDI
x 7
3 More items off the list and it only took a year :oops:
I could have added 2 more in the meantime though, but I sorted them before I could add them to the list, NS drop link and crank pulley.
1/ Suspension going intermittently hard. *** NOW SORTED, ALL FOUR CORNER SPHERES AND THE ACCUMULATOR REPLACED, NORMAL SERVICE NOW RESUMED !! ***
2/ Loss of power / limp home mode. *** NOW SORTED, BY REPLACING THE MAP SENSOR !!! ***
6/ Find a front undertray. *** NOW REPLACED !! ***
My past Citroens :-
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
x 8470
You're getting there HDI :D
Heated seats may prove unrepairable unless you want to get to the heating elements; they normally break and not really very easy to fix at all :cry:
